Joule Ringer!
Started by lasersaber, December 29, 2010, 02:19:43 PM
Laserrod
Hi Lasorsaber.
Best FE U-T video I've seen. Great communication and complete narration of important observations.
Do you find the circuit must have a CFL to work at the high levels you've achieved?
Have U tried other than "leaky diodes"?
I believe the plasma with KR-85 gas gives JT that extra kick! Plasma cause charge separation
& CFT has good chance of containing a # of nano curies of KR gas. Try a Phillips CF, read the box for caution notice.
Thanks man.
Paste answer to... also.
I have asked same on your U-T "light keeps....) video
Stop preventing democracy & stop the buying of gov by the rich. Have a good day and live by what I say.
lasersaber
@ Laserrod
Thanks for your kind comments.
QuoteDo you find the circuit must have a CFL to work at the high levels you've achieved?
Yes, A CFL seems critical to getting it working.
QuoteHave U tried other than "leaky diodes"?
Yes, as shown in my last video touching the wires works just as well.  I have also used two copper pipes in the ground set 30 feet apart. I have also used citrus fruit peels.  I tried resistors but I did not own any that would work.
QuoteTry a Phillips CF, read the box for caution notice.
I will have to give it a try.
@Everybody
Dragon over on energetic forums has replicated this and is getting 15 minute run times.
stprue
@LS
fantastic vid and discovery!  I think you have found something special with this circuit, not we need to understand whats going on in it.  Have you tried 1000uf caps with your ringer?
mscoffman
@All;
I just wanted to suggest the similarity of this JT circuit to the "IMHOTEP
Emergency Light
” that was used to light a CFL using an (unsatisfactory)
electromagnetic relay to do the oscillating function and an std. automobile
ignition coil (three terminal HV transformer) as the step-up coil. This post
is so others might be able to use some of the ideas. A Web Link follows;
http://www.overunity.com/index.php?topic=5296.0
Others found that they were able to connect additional multiple CFL’s in
parallel with the first, without totally disrupting the unit's operation over
“flying” HV leads. This strongly suggest the availability of free electrons
from the environment - extra electrons stimulated to flow in the wire circuit
due to the presents of the initial HV AC signal.
I suggested that using a five sided cube of solarcells located around the
CFL (especially if you can get some of the new Spectrolab 35% efficient cells),
like it should produce a provable and viable OU energy supply.
:S:MarkSCoffman
Mk1
@all
Lidmotor second attempt
http://www.youtube.com/watch?v=mJrutcVNtbs
Mark
Some thought
It seem also that the direction of the diodes is important , but since he mentioned that they are leaking , it means it works like a single wire both ways , but he got really different results depending on the direction , the diodes have to have a second function . I think is to capture the Bemf and send it back in the coil .
