Thanks to ALL for your help!!
Perpetual batteries from Vasilescu-Karpen
Started by exnihiloest, January 08, 2011, 06:20:57 AM
profitis
And its a slam-dunk for the oxygen catalyst spillover mechanism in the above cell..  http://www.researchgate.net/profile/biswarup_satpati2/publication/258059860_facile_preparation_of_Ni%28OH%/292-MnO2_hybrid_material_and_its_application_in_the_electrocatalytic_oxidation_of_hydrazine/links/0deec5260e0e4b67b9000000    ...the effectiveness of a hybrid mix of MnO2/Ni(OH)2 as oxidation catalyst due to oxygen spillover from MnO2 onto Ni(OH)2 which is on the surface of our anode.please note:it will not work under argon or nitrogen
profitis
Thanks markscoffman. Here's more specific examples for Nickel addition to manganese oxides in alkaline sol for improved oxygen catalysis.. http://www.sciencedirect.com/science/article/pii/s0013468612020361 and also here a direct reference to nickel doping of Manganese oxides in alkali for drasticly improved oxygen catalysis http://pubs.acs.org/doi/abs/10.1021/jp0647986
profitis
Here titanium metal is cathodic vs platinum wire in alkaline sol.oxygen spillover going from TiO2 onto platinum.it can also happen in reverse direction if you use sponge platinum.
profitis
This must be documented here too.nickel hydroxide coat ontop graphite(prepared via pyrolysis of Ni(NO3)2 coat and subsequent reduction of NiO2 coat) as anode vs MnO2 as cathode in Na2CO3 sol under air.please note:this will not work under nitrogen or argon.proves beyond all doubt zero chemical combustion or corrosion going on here.I will personaly thrash any single scientist who dare claims to be the discoverer/inventor of this profitis cell.
