COLD FUSION SUCCESS
Started by riccardom70, January 14, 2011, 03:29:39 PM
raburgeson
OK, I'll think out loud a minute. Why molecular bonds do not exist as portrayed in the text books. First the prime orbit of an atom can only have up to 2 electrons. Exactly what is an electron anyway? Don't go to the text book for the answer. Other orbits are either parallel, perpendicular, or at a 45% angle to the prime orbit. Why then is the water molecule at the angle it is between the nucleuses of the three atoms in a water molecule?
OK, by description the hydrogen is positive and the oxygen is negative. Not likely. Yes that would create an attraction. How ever it would probably create a fusion reaction. There is a barrier between the atoms, they stay individual atoms.
Cohesion, adhesion and surface tension, what are the actual forces that cause these properties? Yes I asked what forces!
Quantum Physics offers that an atom is a closed loop. That is helpful if it is right. Which force would make the oxygen atom rather bond with oxygen atoms than hydrogen? Are these forces even mentioned in the text books. (Not so far as I can tell.) I have seen mention of electro-magnetism and gravity. Little other references are made.
Distances of these forces and their effect must be critical. In other words does the force that allows 2 electrons in the prime orbit appear in bands that allow the number in further orbits to exist? What about the force just outside the valance orbit that keeps the atoms identity? The force that causes impenetrability?
Is the force that determines electron orbit size and number as constant as the force that makes planet orbits identification mathematically computational by formula?
We have to start from scratch you know. I'm sure you can quote the textbooks, 1000s of scientist are struggling with the fact that the textbook explanation does not work. Maybe the angle of the atoms in a water molecule are such because the force holding the hydrogen atoms apart sets the distance between those 2 atoms. Of course I am discussing the average distance because I believe they are correct that the distance varies.
pix
Last info from Rossi E-cat.
Because he hasn't international patent yet he is not disclosing a "secret" catalyst, but at the same time he wants to start commercialising his E-cat cells, so he came to idea installing a self-destructive mechanism into the cell in case someone wants to open it and find out what catalyst material is used.
Another greedy bastard! History is repeating again.How many groundbreaking inventions were taken to the grave together with the guy, because he was so greedy to give this to the humankind.
Anyway- this is invention originated from prof. Piantelli, that Rossi bastard only perfected ( engineered)it to obtain a better results.Read Piantelli patents and papers and you will find how to replicate process.
After reading the patents and and Piantelli papers I came to this:
1.Nickiel nanopowder needs to be annealed at about 400-500 deg C in the vacuum for a week or so to remove all gaseous impirities.
2.Anything that breaks atomic hydrogen H2 into monoatomic  H will help. So adding for example wolfram pieces or powder into nickiel powder will start process. If I remember well in high temperature Wolfram breaks atomic hydrogen H2 into H.The point is to let react nickiel powder in high temperature with monoatomic H atoms.
3.Maybe  adding potassium, K3+ will also start heat production, in case process is similiar to Blaclightpower invention.
4.After annealing slowly introduce hydrogen gas into the cell, heating it at the same time by electrical heating element.And look for the results.
In my opinion Rossi only mastered process already invented and known.There is still no solid explanation how it works, but it has to be or Piantelli or Blacklightpower related stuff, or both of them at once. I will try to experiment since this is really easy. Any refrigeration trained engineer easily could set-up such cell.
Regards,
pix
Doctor No
With this above, how You had described Rossi, You had personalized self: You are selfish and jealous. Rossi knows well about such peoples as You, but what he only should to do, is own party as wanted his fellow Beluzzo to do 50y. ago. As i stated earlier: free energy, even civilian, is not for all. Only for chosen first. I think, serious people don^t need an explanation.
Omega_0
Good news : This experiment got replicated. It produced 8 W for four days. Replication is done by a well know mainstream scientist with good credentials.
http://nextbigfuture.com/2011/06/brian-ahern-getting-8-watts-in-low.html
The above link has all the details needed to replicate it. (You can call it open source if you like, but its actually the method of experiment which produced OU)
The chances of it being a fraud are diminishing. I'm sure many more will jump in and replicate this. However, this is beyond the capabilities of an average ou.com hobbyist (like me) as it needs some substances in nano-powder form and a high-end oven.
pix
Quote from: Doctor No on June 11, 2011, 06:41:11 AM
You seem not be capable of understanding written text.
1.If I would be selfish- I wouldn't describe my findings on the open forum. Understand? All this process "trick" lies with annealing nanopowder of Ni under vacuum.Triple purging is method well known to refrigeration engineers, it removes all the gases and moist from the system.So triple purging of Ni powder with H2 will do the job.
2.Rossi is simple arogant bastard, just clever enough to master process invented by Piantelli and others.He is looking for the money.Second secret lies in large reaction area of Ni nanopowder.Third secret lies how to breake introduced H2 into atomic H.
3.Free energy "only for chosen ones", as you state? And WHO is selfish anf jealous? WHAT are you doing on this forum? You think you are "the choosen one"? buahaha  ;D
pix
