Aether is time... and time can be increased
Started by soliris, January 19, 2011, 05:51:00 PM
Bob Smith
QuoteThe Law of polarity is the fair way to work with the double tension between the entry point and the exit point of a magnet, a physical body, a planet.
Yes, the aether flows through everything. Certain elements, properly arranged, seem to convert this double tension into useable forms of energy. I think Tesla drew on this when he developed his Radiant Energy Collector.
Perhaps you are right - our children may be playing with this one day. The greatest secrets are often more easily understood by those with childlike hearts and open minds.
All the best to you, Soliris.
Bob
Bob Smith
QuoteBut it's not exactly the truth: every material element has got an entry point and an exit point...with two opposite directions, at the same time, like on a highway.
Soliris, let me add to your statement that not only does every material element have an entry point and an exit point, but also a resonant frequency.
From what I have been able to see, resonance is key to accessing a kind of "pouring in" of the aether which engulfs us (as you so well described).
How is resonance related to polarity?
Bob
XS-NRG
Quote from: Bob Smith on January 24, 2011, 09:33:01 PM
Bob
That is strange Bob maybe your eyes were closed?
I have seen it is NOT resonance and i would describe it more like a brute force methode to force it out.
soliris
Hello Bob
You make investigations on the side of the resonance, and me on the side of the polarity of the temporal power.
It is a strange crossroads.
For a body or object is visible in this dimension, there is actually a tension between the single points of entry and exit.
One day I modeled what happens inside a magnet
On my drawn pictures, the incoming energy is unfortunately deflected WITHIN a magnet, exactly like a spiral, before exiting through the center ... to where? Beyond the wall of Jukovsky: beyond the "wall of perception", where we find the open field of the ether, simply.
However, there is the problem: the magnets "aspire" energy from the environment, and we have to reverse direction, by forcing the magnets to bring the energy from the wall until us (and we'll see effects like; free energy (but how to use it, you told me) and antigravity (I know how to use it !!! ...)
We must break the spiral motion by transforming the internal tension to external resonance with the field of aether itself.
Our body experiences more compression of the ether, like magnets. "Compression" is not a controlled voltage between the point of entry and exit ...
All this, requires a continuous reflection: we need additional evidence, just one detail is forgotten: we are talking about the same things.
What is missing us, Bob ? ...
soliris
soliris
It is a strange crossroads, because I lack knowledge about your area of research ..
For a body or object is visible in this dimension, there is actually a resonance between the single points of entry and exit.
The incoming energy is unfortunately deflected WITHIN a magnet, spiral, before exiting through the center ... to where? Beyond the wall of Jukovsky: beyond the "wall of perception", where we find the open field of the ether, simply.
However, there is the problem: the magnets "aspire" energy from the environment, and we have to  reverse direction, by forcing the magnets to bring the energy from the wall until us (and we'll see effects like; free energy (but to use it, you told me, and antigravity (I know how to use it !!! ...)
We must break the spiral motion by transforming the internal resonance to external resonance with the field of aether itself.
soliris
