1 kW zero point energy @ Peswiki.com
Started by Low-Q, February 10, 2011, 07:48:07 AM
LightRider
Here is a print screen of the source code.
LightRider
ps.: it remains the math... to see if the resonant frequency of 100Hz is good.
LightRider
L = 404000 uH (approximation)
C = 0.23 uF (from source code)
Freq = 522.11 Hz
LightRider
edit1: L = (0.394 * r^2 * N^2) / (9r + 10A)   (In Metric Units "cm")
edit2: Freq = 1 / (2*pi*sqrt(L*C))
edit3:
r = 0.045 m
N = 1600 turn
A = 0.01 m
edit4: "copper wire from which the coil is made has a cross section area of 1.0 mm2, which is not too much for an electric alternating current of  Imax = 18 Ampere in the peak"
Look at the table 18 Gage SWG (or 16 Gage AWG) = 1.17mm^2 @ 22 amp max (3.7 amp )
LightRider
From "http://philica.com/display_article.php?article_id=219"
remark in "()" are from me...
"...We approach to the adjustment of the system parameters with all resistors being switched of (Ohm’s resistor and load resistor both being zero). Then we start the rotation of the magnet with a well defined number of revolutions per minute (6000 RPM). Under these conditions, we start to adjust the  electric LCR-oscillation-circuit to the same frequency as the rotation of the magnet has. At the beginning, the electrical circuit did not contain any energy. When the adjustment of the electrical oscillation-circuit is close enough to the frequency of the initial rotation, we have a state of the system, which can be understood as the double-resonance of the electrical and the mechanical parts. In this state, the system begins to build up classical energy by alone, and the new classical energy is coming from the zero-point reservoir.
As soon as we have found this point of operation, we can slowly introduce the Ohm’s resistance of the coil’s wire, in tiny steps, step by step, into the differential equations. But we have to perform very small steps for the enhancement of this Ohm’s resistance, and always to renew the adjustment the parameters of the electrical circuit (capacity, inductivity, number of coil’s windings) step by step, in order not to lose the state of operation, in which zero-point energy is gained. This procedure has to be done very carefully; otherwise we would lose the information about the good operation of the system. Step by step we learn how to operate the system in a way, that the power-gain from the zero-point-energy is large enough to support the complete coil (with its whole Ohm’s resistance) with power. Very carefully we give attention to the double-resonance in order not to lose it.
When this mode of operation is found, the rotor runs safe and reproducible with the system parameters we have found, to be a self-running engine...."
LightRider
Omnibus
All this is well and good except for the zero point energy part. Just mentioning it in the text doesn't prove at all that the source of rotation is zero point energy. First things first -- has he actually achieved self-sustaining run? If yes, then this device has to be replicated without delay. Only replication of the self-sustaining run by independent parties may turn this into something worthwhile. We've seen way too many claims for self-sustaining devices that have never been proven to be so independently to take one more claim seriously. If he hasn't achieved self-sustaining run then very careful energy balance has to be done before attempts to explain theoretically (zpe shouldn't even be a candidate) something that hasn't even been proven to be OU.
LightRider
Quote from: Omnibus on February 10, 2011, 09:47:24 PM
This comme from "Professor Claus W. Turtur from the University of Applied Sciences in Germany".
"He is a highly regarded theoretician who proved zero-point energy conversion in a published paper"
http://peswiki.com/index.php/OS:_Claus_W._Turtur:_Zero_Point_Energy_Converter_in_the_Kilowatt_Range
have you read his published paper ?
(It's theories, computer simulations and some small experiments... interesting)
LightRider
