Practical Method for Production of Water Fuel with Piezoelectric
Started by The Power To Be, February 17, 2011, 06:11:02 AM
The Power To Be
Quote from: markdansie on February 21, 2011, 03:10:13 AM
@The Power to be
Thank you for sharing
You have my attention.
Appart from the water does anything else get consumedor or need replenishing.
Having read your other threads you are a serious researcher.
The devil is in the detail...have you any figures for the power needed for instance to run the electrics to produce the gas to run the generator. IE is it possible to close loop.
I have seen no over device or replication of a device that has managed to do so.
Kind Regards
Mark
The test 6kwh generator was closed loop with further developments of low pressure storage tanks for H and O2 to enable start/ stop operation without the need for fossil fuel.
ZnO crystals just needs permanent adhesion, there are many ways of doing this, composite plating, ceramic etc, you decide.
My effort is not to give you a solution, but help you develop your own solution in your own unique way, Energy is around you 24 hrs, you just need to see it!.
The Power To Be
Quote from: Qwert on February 19, 2011, 11:30:40 AM
Years ago I have read an article in a pop-tech magazine, that pure hydrogen makes steel parts brittle when contacting them, by fluxing away the structural carbon from the steel lattice. So, be aware of this when using your car's engine! Just "Google" it. My fast "Googling" research can confirm this here for example: http://www.springerlink.com/content/p475551841jhh711/
This system is a primitive method of utilizing widely available Internal Combustion Engines. The gas mixture contains 60 to 80 percent atomize water, only enough HHO is injected to make water fuel combustible, the result is a cooler running engine which shall prolong engine life.
There are oil additives such as ceramic that you can use if you are so concern of such damage, It has not been a concern for me.
MasterPlaster
This point is normally raised by people ( I don't mean you ) who in an underhanded way
want to distract the would be explorer from continuing his search.
Finding a way of creating free energy does not mean we can all go home and relax.
I am sure the hydrogen solution brings lots of opportunities for metalurogists and the steel industry!
The Power To Be
I have had time to see this through clearly.
Guys, I am very sorry but I will no longer pursue this project.
It is not my call, it is yours.
I must continue on my own journey.
I wish you all the best.
ramset
The Power to be Quote:
This is a  full disclosure of the facts that will enable humanity to attain a sustainable civilization without the need for oil. Full non proprietory disclosure into the Public Domain by me, the origin inventor. The Power To Be.
So much work you have done!
So many intriguing things you say!
You Know everything can change with a thought?
Give it another think!
Thanks for sharing
Chet
Thanks Grandma
