Practical Method for Production of Water Fuel with Piezoelectric
Started by The Power To Be, February 17, 2011, 06:11:02 AM
Slovenia
One of our team members from Energetic Forum, Vickers, just shared an easy way to make the Powerme crystals in an easier alternate way.  He's had great success with this method.  Here you go:
From EF by Vickers
Hope Powerme dont mind but I would like to simplify some of his very simple instructions. (just to speed things up a little).
Zinc oxide can be bought at any pottery supply outlet over the counter.
May not be nano... but if u really keen u can grind the hell out of it with a mortar and pestle for as long as u can.
Can concentrate ammonia easily and safely using a crock pot with upside down lid full of icewater. Place a small collector bowl in center of crock pot.
Instead of mag stirrer and hotplate use a plastic drink bottle. Ur household hot tap water is 60C. To prevent fumes make sure u seal it as mentioned in powerme first post. This is perfectly safe. There will be zero pressure build up. Learn boiling temp of water VS boiling temp of ammonia.
Immerse bottle in hot tap water to heat and shake the hell out of it every minute or so. The longer the better.
Freeze overnight to concentrate the ammonia and slowly heat again to maximize the reaction of highly concentrated yet safely contained ammonia.
Pour onto oven tray and evaporate.
Scrape up ur crystals.
Done.
petar113507
Two things.
One -- Distilling the ammonium is easiest done inside the freezer, and a jar of some kind.
Bring it down to 0* -- the water freezes, and the ammonium doesnt.  Use a metalfilter, to "screen" off the ice.
Do it twice, and it's WAY above the concentration that we need for this experiment.  THAT is the simplest that I've found, and stick to this one as of yet.  Takes about 6 hours to distill it twice.
Second,
Those "natures aids" reminded me of something I read about shaman, and psychoactives.  They called Salvia divinorum  the "shaman's herb".  Someone I knew, also grew crystals (a concentrated version of the psychoactive in Salvia) from the stuff, and tripped out really hard.  Kid never was the same thereafter.
Drugs, are not the "real" way to open up various parts of your endocrine system (chakras) -- but can temporarily open them up, so that you know when the thing is "open" or not.  For some people, it works because it gives them a roadmap of getting themselves more "enlightened"  but because your body needs to 'process' the chemicals, it can be harder on your liver or kidneys.
Knowing when the different parts are "open" can let you know what you need to do, on a daily basis in order to become more "open".  Now, taking drugs -- won't help you if you don't pay attention to where your feelings go in the first place.  This might be a little bit over some people's heads -- but feelings travel places in your body.
When you are frustrated, or angry -- Most people know the "lump" in your throat. How did the lump get there?  Where does it go when you get rid of it?  (Answer here, Most people know the sigh after being frustrated & had solved it -- The sigh is the physical indicator of a deeper process.  When I say the feelings "travel" between bodyparts -- I am asking you to pay attention to where your feelings go, or how they feel when they go somewhere.  You become more sensitive with this over time.)
Also, people don't always pay attention to the "tingles" that happen when you have a good idea, or have done something right.
Your body is a very powerful tool, and will tell you quite a bit you'll need to know.  All you need do, is listen.
If you are sensitive to these internal processes, and are aware what happens to you on a regular basis -- experiencing the altered state, can be insightful.
This is terribly off tangent though.  Onward to the pizeo-electric today and tomorrow!
==Romo
The Power To Be
Hey Slovenia,
Thank you for your continued effort. Your pvc idea is great, it is a very durable material. My little shoebox was just a quick way to entice people into seeing the many possibilities of water as fuel.  Experiment with your setup, you will come up with your own unique way.
For self eccentric, it will develop over time, much like speech process. My process started with cosmic orgasm, and the manifestation of intelligent entities, yes they do exist, hence I was a Dog but don't dwell upon the phases, keep moving.
Romo, you have a great mind, there are many papers though restricted in Sonochemistry and other published works that employed Keeleys findinds of water dissociation at 43khz. The ZnO crystals amplifies the HHO production.
Nature is the best way to go, but a concentrated natural dose will allow one to experience the higher realm first hand, not a good way but a helpful one, Leary had already explained them but it's a tiny portion of the All.
Good luck all and thank you for your efforts, everyone has their own unique way.
Slovenia
Hi Romo,
Thanks for going off track on the higher senses thing.  I appreciate it very much.  I think this process is also important to our work or Powerme wouldn't have referenced it so much.  He said a lot of things that were very insightful and interesting, but I couldn't really relate to this aspect, because I've never utilized it before.  I've just been running on empty with the regular brain.
Best Regards,
Slovenia
Slovenia
Thanks Powerme for your continued support.  Most of us need it because we don't have the gift yet that you and Romo share.  We are fortunate to have both of you sharing with us.
Quote from: The Power To Be on March 14, 2011, 02:57:33 PM
Hey Slovenia,
