Practical Method for Production of Water Fuel with Piezoelectric
Started by The Power To Be, February 17, 2011, 06:11:02 AM
RAD-HHO
You can buy the circuit board from digikey for $96.
http://parts.digikey.com/1/parts/1680633-nebulizer-unit-12vdc-13-2w-nb-80e-01-h.html
Anybody have any luck looking at the patent power mentioned?
RAD-HHO
This is all I got.
100k to 1.5Mhz in accordance with the change of temperature of the water. My fogger is at 1.7M. This tells me it needs to be decreased, not increased.
Quote:
PROBLEM TO BE SOLVED: To decompose water into hydrogen and oxygen by using an ultrasonic machine. ; SOLUTION: Water is decomposed by controlling the wavelength of the ultrasonic machine in accordance with the change of temperature of the water, and the frequency is preferably 100,000 to 1,500,000 Hz. Clean hydrogen can be efficiently obtained and oxygen as well. ; COPYRIGHT: (C)2005,JPO&NCIPI
The Power To Be
Romo
What you believe becomes your own Reality. Is something hapening, Yes/No, It does not matter. Fear is only a mind game, believe and you will become the victim. Is something happening to Earth, Yes there is. But do not Fear as you will be lost and confused. Demand proof, do not believe. Turn off your TV, forget about the News etc, Don't fall victim to the hoax and prank being played today, use your own intelligence.
RAD
I must say that I only use simple things from 19th century era, works just fine,  I had tuned my chamber with a balloon. If you are measuring water at 1.7mhz, then you should have lots of HHO already!.
You don't need to buy digikey circuit, you can make it. Or if you want to buy ready made, look at Alibaba, they have the same exact thing for fraction $, or better go taobao.com.
Slovenia
Crystal oscillator circuits are old and easy to build.
You are working with ultrasonic waves here. Musical instruments will give fine examples.
What material and  geometry exhibits excellent acoustic harmonic qualities?, use that for your atomizing chamber.
How to adhere crystals, many different ways, what is best for you?. Other researchers used flexible materials, I use solid, it don't matter, what ever way that is practical for you.
How do you harvest ultrasonic waves, what shape or geometry should you make the collector?.
You answer is widely available. Forget wikipedia and these forums, look elsewhere. What did the other inventors used?.  Patents, old books etc.
Slovenia
Great to hear from you Power To Be.  Thanks for sharing!!
Quote from: The Power To Be on March 18, 2011, 09:27:09 AM
Slovenia
Super God
Maybe we can bypass the need for a specific geometry by just maximizing surface area that the waves will contact. Just my thinking...
>9000
