Practical Method for Production of Water Fuel with Piezoelectric
Started by The Power To Be, February 17, 2011, 06:11:02 AM
Slovenia
What We Know:
1) The optimum voltage for running the cell is 36 volts. Power1 converted 12 volts to 36 volts with his circuit.
2) Recipe for making zinc crystals.
3) Optimum frequency of 42.8 KHz
4) Power1's transducer is a 45 KHz unit
5) Transducer should be inside the cell, so it needs to be immersible.
6) Cylindrical tank/cell lends itself to runaway reactions.
7) Should have a transducer horn of brass and a receiver of brass.
8) The cell only uses tap water.
9) Use only Krupa plugs or other high quality plasma plugs.
10) He recommended utilizing the JT Circuit & Pierce Circuit in the cell application. He said complicated circuits were not necessary and recommended using the easiest methods possible.
11) Zinc crystals need to be in the cells water for optimum results.
12) We need to read all Power1's required reading especialy the "Treatise of Physics & Chemistry", so that we'll be on the same page with Power1. Otherwise, he said we are wasting his time.
What We Don't Know:
1) The actual configuration of power1's cell.
2) We don't know the actual configuration of his transducer.
3) How he plated his zinc crystals onto surfaces.
4) Which surfaces he coated with the zinc crystals.
5) Anything about his lead sulfide 24/7 battery cell that collected all the energy. This was to be the next project he talked about.
Feel free to add to this list and share ideas and answers!!!
Slovenia
There is finally a little activity on this thread at Energetic Forum, so if you are interested go to the following link and check it out.
http://www.energeticforum.com/renewable-energy/7365-discussion-best-way-use-heat-hho-generate-electricity-24.html
Slovenia
Slovenia
Connect With Your Inner Intelligence (How It's Done Book)
I have found the book that will help you connect with your inner intelligence at Power1 eluded to. Here is a link to the book, "The Power of Your Subconscious Mind".
http://www.ichoosetoheal.com/downloads/the-power-of-your-subconscious-mind.pdf
I've been reading this book and think it is truly an incredibly worthwhile read.
bugler
Hi Slovenia,
this is bugler. I was banned from energeticforum by jew Aaron for daring to expose the jewish criminal network.
These jews are everywhere protecting the crimes of their people so the rest won't find out about it and keep paying taxes and interes forever while they kill us all.
