Shorting coil gives back more power
Started by romerouk, February 18, 2011, 09:51:45 PM
MasterPlaster
Quote from: Bruce_TPU on February 20, 2011, 07:28:07 PM
One wonders if a Solid State version could not be made, using an earth battery.  Make and break the two metals of the primary to create AC on the secondary and then short the secondary coil at the Sines peak and dump into a high voltage capacitor.
Just a thought for anyone with a proper wound earth battery.
You mean like this?
http://www.intalek.com/Papers/Handout3.pdf  ( page 25 )
Kunel's patent:
http://www.overunity.com/index.php?action=dlattach;topic=1762.0;attach=4295
romerouk
@e2matrix
I am using a HDD motor to hold the rotor disk and the wires u see are comming from the HDD motor thinking that I can use that at a later stage, at the moment not connected anywhere.
In the youtube video I posted, I was using a reed switch to drive my small coil, now I have changed it with a hall sensor and a transistor to drive the rotor.It uses about 70-90ma do do the work.
I have added extra coils and more magnets and now I can get better and faster charge but still having a 6 volt battery in the system. With capacitor I have tried everything I know and sugested here too but after about a minute the voltage in the capacitor goes below 3 volts and my hall stops working due to insufficient power.
The position of the reed switches is critical to keep the speed unaffected while shorting.
I am working on a circuit where the reed will trigger a small circuit and for that period of time to short the coil multiple times.
Below is a picture with the setup at this moment.
One more important thing is the arangements of the coils to make sure none of the coils are shorted while the driving coil is at ON time.We need to send the charge to the battery while the driving coil is at OFF position.
Bruce_TPU
Hi romerouk,
Pls see below. Good luck!
Cheers,
Bruce
romerouk
@Bruce_TPU
I am planning to do that too.
Thank you,
RomeroUK
e2matrix
RomeroUK,  thanks for the reply on that.  I assumed that was most likely how you had it setup.  I've got a bunch of old HD motors I need to strip a few out for things like this.  Sounds like you are heading in the direction like konehead described Ismael is doing of trying to do mulitple hits on the peak.  Exciting concept although I'll consider myself lucky if I can just get to where you've already been with this.  I think it's a good sign and quite surprising that your capacitor runs it for even close to a minute.  I'll probably just focus on using a battery and getting it to where it keeps it charged.  Glad to see you on board with this concept!
