Shorting coil gives back more power
Started by romerouk, February 18, 2011, 09:51:45 PM
Feynman
QuoteIn tests I did with the Thane shorted coil what I found is shorting the coil reverses the magnetic field of the core.
i_ron
QuoteThe field reverses on a short, then instantly returns on removal of the short,
generating an intense induced pulse.
This is a really fascinating result, thanks.   So I think we definitely have an interesting EM effect that needs investigation via further experiments.
i_ron
Quote from: Feynman on March 18, 2011, 11:42:49 AM
Thank you!
Here it is then with a single short. See the induced voltage descends to zero
on a short with no negative collapse spike and then springs to life on removal of the short.
Red trace is with probe on divide by 10
Blue trace is output of zero crossing detector circuit
Ron
Feynman
@i_ron
Okay cool, these spikes are well in excess of 25V... what is your input pulse voltage?  If you can paste any other technical details of the setup when you get some time that would be helpful too.
i_ron
Quote from: Feynman on March 18, 2011, 12:18:18 PM
@i_ron
I can't remember if I posted this here? But anyway, a bit messy, lol
On a DMM the coil output is 6 volts (AC)  with coil shorting the output is 70 volts after the FWB
As many know I worked with Thane for awhile and built two rotors for him. I was never able to show the results he claimed.
But all this was before coil shorting and so I have never followed up on the implications here. However, rubbing shoulders with some clever people I am gradually learning....
BUT, if the coil reverses polarity on a short...
One should investigate what pole is formed from a shorted coil as the magnet leaves the core....
Ron
i_ron
