Rosemary Ainslie circuit demonstration on Saturday March 12th 2011
Started by hartiberlin, February 20, 2011, 06:14:05 PM
neptune
Hi Rosemary, Poynt 99 does not seem to be about at the moment , so can I offer my opinion on what he is saying ? The Fet is acting as a closed switch , and its resistance is assumed to be negligible . So we just have 2 resistors connected in series across a 60 volt battery , We have the load resistor , 11 ohms . And we have the shunt , at one quarter ohm . Imagine instead that the load resister is 10 ohms .and the shunt is one ohm . Now , if we measure the voltages across each resister in turn , we find the the voltage across the load is ten times the voltage across the shunt .That is how he arrives at his voltage figure , being the voltage across the shunt .So going back to the original values , the load will have 44 times the voltage across it than the voltage across the shunt . There will be approx 58.6 volts across the load and about 1.3 volts across the shunt . 58.6 plus 1.3 = 59.9 volts . Near enough for me , and I failed my maths exams .@Poynt99 feel free to tell me if I am wrong .
Rosemary Ainslie
Quote from: neptune on March 23, 2011, 01:26:15 PM
Ok.  Thanks Neptune.  I'm still not sure why one doesn't take the actual voltage reading.  But it's close - so.  I get it. A kind of check?
Now I'd be very glad if Poynty could print those pictures.  I've finally opened them - but would be glad to get them up here - in case anyone, like me, struggles.  Can you oblige us Neptune?  Someone?
Kindest regards,
Rosie
woopy
Hi Mag and Rose
i made a quick test with a MO high voltage cap with 0.95 micro F, so it discharge fast enough to see what is going on here.
The battery is at about 4.6 volt and goes to a BAT 43 schotky diode (very few lost in voltage) than to the 220mH inductance(primary of MOT)  ant than to the cap and back to the negative.
I enclose a scope shot .
when i close the circuit the voltage jump to 7.6 volts than the cap descharge down to 4.6 volt (that is the battery voltage, and stay at this value until i open the circuit and the cap goes on descharging.
The best result i got today is a 1.7 time the voltage supplied. In this pix it is 7.7 volts(the freewheeled voltage ) / 4.6 volt (the supplied voltage) = 1.67
Not bad at all.
And in this config (but with a much stronger diode a BYV26D ) , by shorting the cap i can get really high voltage (MORE than 400 volts) impressive.
Now how to use this effect ?
Will test your new circuit ASAP, any idea for the resistor value?
good luck at all
Laurent
penno64
Last time - I promise
posted feb 19 in shorting coil thread -
Hi All,
How pertinent is this guys video now ? (1 and 2)
http://www.youtube.com/user/NRGFromTheVacuum#p/u/10/2cUS03yNl40
Looks like it's been under our noses all this time and we couldn't see the forest for the trees.
Kindest Regards, Penno
________________________________________________________
Penno, (Garry)
nul-points
Quote from: woopy on March 23, 2011, 02:05:51 PM
Laurent
hi Laurent
nice testing - but you may want to reconsider Mags idea of a diode across the battery/switch - as shown, it's forward biased and if the switch gets closed for too long, then the 'magic smoke' is likely to to get released from either the new diode or the battery!  :)
interesting to see that shorting the capacitor has such a strong effect - especially when the current fashion seems to be 'shorting coils'!!!
cordialement
sandy
http://docsfreelunch.blogspot.com/
