Joerg Raimund Hempel and his Ionic Magnetic Power IMP CAP Charging
Started by hartiberlin, March 03, 2011, 08:08:48 PM
wattsup
My first question when i saw his video is "How does he make the contact between his removable "magbat" and the base onto which he places it?
Looking up close I found that the red tapped end was tapped closed and the blue taped end was tapped open and there is a small metallic stem that is inside the blue tapped end. Then there is a wire on the base that is there to contact that metal stem. (See images.)
When the video demo started, he had already set up the magbat on the base and put that contact wire through the blue side needle hole. It was simply passed through the the needle hole and held tight enough to do the demo. Once he removed the magbat, that connection was severed so when he put it back on the base, he would have had to redo that connection point and hence divulge how he got his connection between the magbat and the base.
Then looking at his patent sheet 1 of 4, the magbat has an internal winding like in bucking mode to there are only two contacts required on the magbat as described above.
Then on his patent the wound coil comes out of the magbat and is in parallel with a capacitor bank and the load, so those two black rectangular containers must be the capacitors, but are they? That is the question. So if those two boxes are not batteries, then his device is truly a quandary. But if they are batteries, then this is simply a good show.
As to how it works, I have a theory but that's all it is, a theory and not really important right now.
wattsup
bolt
interesting OBs but its all too much like the TPU. Nice videos to wet your appetite but the main meal is missing.
wattsup
@stefan
I am sorry to seem to break the party but I feel when I see something I must come forward and hopefully sooner then later.
I think I must clarify the above post a little more.
The image entitled magbat-contact-points1.jpg was grabbed before he removed the magbat. Notice how the contact wire is connected inside the stem needle hole.
Then the image entitled magbat-blue-end-matellic-stem3.jpg was grabbed just as he puts the magbat back onto the base. Notice now the contact wire is not connected because this would require some direct attention to that connection point. Something he would not want to do in a demo.
You see, the main crux of his demo holds because his magbat base only has one copper strip onto which the magbat is positioned. So automatically, one would say "how the hell is it possible to just place that magbat onto one strip of copper and have it work". But now we see a second contact point and this changes the game.
Before we waste another century I suggest you find out about them black boxes. (bb) If they are capacitors, then this is very good. If they are batteries, then this is very bad, or, there is a side-effect that is worth looking into.
So let's look further. Both meters where connected on the black boxes and they did show less then 1 volt when he discharged. Don't forget one thing, I am only analyzing this because I don't want to waste more months, but I can tell you now, it does not look that good.
At the beginning of the video we can see the load cap red wire was not connected to the bb. At 43 seconds he shows the Fluke287 that is connected in parallel to the bb and it showed .1545 vdc. He wanted to show us the bb was not charged. But what you don't know is he was shorting out the bb while the camera was on the Fluke meter. But the camera was on the Fluke to long and when he removed the short we see the voltage rises to 21.110 vdc, so the bb is a battery after all. Two in series of probably 12vdc each.
At 1.31 he shorts out the load cap to bleed it and shows .027 vdc on the green multi-meter (gmm). The load cap is still not connected to the bb.
AT 2.19 HE PUSHES THE ON BUTTON FIRST THEN HE HOLDS THE RED WIRE FROM THE BB AND THE RED WIRE FROM THE LOAD CAP AND AT 2.38 HE MANUALLY TOUCHES THEM TOGETHER. The On switch means nothing because the bb is a 21 volt battery and it does not matter if the switch is on or off, but he wants you to think it does matter.
You see the voltage rises on the load cap to 19.54 vdc.
At 3.24 he shorts out the load cap and we see sparks and the shorting wire does glow off the positive end. This is the curious part, that everyone will say "how can you charge a 1 farad capacitor to 20 volts in one second and then make that wire glow when it is shorted?
OK, does anyone have a 1 farad capacitor that you can charge to 20 volts and then short out with a nice wire. I think 20 volts 1 farad should singe the wire so fast and blow it up. Not just make it glow. Someone can do the test please and report back.
If you report back and the 1 farad cap does in fact kill the wire immediately, then we know his 1 farad capacitor IS NOT 1 FARAD. He could easily hide a smaller cap inside that big cap and make you think it was charged to 20 volts in one second.
If the report back is exactly as we see it in his video, then we have to take one step back and now we know there is something special here, but not before because the video does not give me good vibes at all. It gives me the trickery sensation all over again. We have seen them before.
Now at 4.19 the gmm is at .669 vdc just before he hits the two red wires together again. He holds them together much longer then the first time and the voltage rises to 17.30 vdc then when the cameraman sees he is going to pulse the wire again, the cameraman pans off the gmm on purpose while he flicks the wires a few more times to then bring up the voltage to 20.38 vdc. This is not OK to do like that but probably the bb power was dropping and he heeded more time to charge the cap, But you can realize the conscious effort on his part to avoid letting you see certain things is just troubling.
At 5.05 he shorts the load cap again and we see another glow of the wire.
The rest of the video he talks, lifts up the magbat, puts it back, takes a shot under the glass table but I could not see under the load capacitor.
In general I am very skeptical of his video because he obviously is looking to hide things and hide behind tricking with the camera, and, actually doing a very poor job of it. I personally think this is a dud,
Firs of all why have two volt meters at the same point. That was weird and he did not realize he showed 22 volts on the Fluke meter. He tried to trick us into thinking the bb had no voltage.
Then, he did not show the capacitance of his 1 farad capacitor. Since he was using such a big capacitor, he should have shown that measurement as well because the capacitor is bulky and could easily hide a smaller capacitor inside of it.
The test I mentioned above would put that question to rest. But if you want my opinion, a 1 farad capacitor charged to 20 volts would have just toasted the wire in half a second. So many things are not right with this demo.
Man, I love these videos, they are such a challenge. But this one was too easy. I do not believe this person is seriously authentic with us and would advise extreme caution especially if you are thinking of sending money, because at one point, that may be the goal.
If a new demo is done but with more measurements, verification of the capacitance of the load capacitor, measurement across the magbat base and then we see something out of the ordinary, then I will reconsider, but right now, I would say be careful because it does not look good.
Yes, I could be totally wrong, ignorant, blind, but, I love OU to much to leave any stone unturned, hence just making sure that our time and our attention is not deviated for another pipe dream. But deep down, I hope I am wrong, but hope is not enough.
wattsup
i_ron
Quote from: wattsup on March 07, 2011, 11:49:46 PM
@stefan
snip
wattsup
Excellent observations wattsup! I believe you are quite right. It is a nice fit with my unease in certain parts, I mean if you did have something that worked as stated, why the poor, rambling, confusing demo?
And why so many unidentified items on the table?
Ron
e2matrix
Sounds like it would be a good idea if Stefan would invite him over here since he is apparently in Germany.  At least Stefan can talk readily to him in his native language and if he only speaks German then we could ask him to use Google translator or we can use it here on his posts.  But either way it would be nice to know his reaction to such a request given wattsup's observations.
