Thanks to ALL for your help!!
FREE ENERGY AC GENERATOR ?
Started by e2matrix, March 10, 2011, 06:02:45 PM
Omnibus
Would be nice if you could upload the zip file of your PSpice 9.3 version here with the upload utility. Hope it fits within the size requirements.
teslaalset
Quote from: Omnibus on March 19, 2011, 06:49:25 AM
The file is 370 MB, so it will not fit.
I'll send you a PM with alternative instructions.
Omnibus
@teslaalset,
Thanks a lot. Download started. Will see how long it will take.
I wonder, what's the benefit of using 9.3 rather than 9.1? The latter is easily found and installed and that's a plus for having these OU claims tested by as many people as possible. Any little obstacle, such as software not readily available, deters people (I know I won't bother). The situation OU research is put in is bad enough to add new obstacles to it, don't you think?
teslaalset
Quote from: Omnibus on March 19, 2011, 07:12:35 AM
@teslaalset,
Yes, it's a bit awkward all these versions of Pspice.
I had a look at the V9.1 also, but I like to include commercial component libraries, to be able to use real component spice models as well. That is why I start using the free version of candence.
This is the disadvantage of remote cooperation I guess. Let's see whether you are able to download, install and use the same version I use. I looks like you will be able to use the two versions in parallel. I was able to use your V9.1 version files in the Cadence, so it seems there is some backward compatibility.
Omnibus
@teslaalset,
Installation done. Now, file's open. Can't find the libraries you require, though.
