The Gabriel Device, possible COP=8
Started by Feynman, March 22, 2011, 04:07:09 PM
kampen
@ All,
anyone interested and located in EUROPE for a purchase order for the 2 pcs. Toroid Magnet Housing (L&S Industries USA) feel free to contact me by PM.
I can collect/handle all European orders and then make one volume purchase order to L&S Industries, so we can get this cheaper if he sets it up for all interested at the same time and item cost (price is quantity dependent).
Upon receipt I will re-mail it within Europe free of shipping charge to You.
Hope this will be any help, let me know.
wayne49s
Quote from: Magluvin on March 25, 2011, 05:45:11 PM
But, and I thought about this at work, the secondary field produced when current flows through it, only ever makes it to the shell and not beyond, thus never cutting the primary conductors  ;]
Here is a pdf that shows how fields propagate in a transformer. once you get this, my theory works. =]
Interesting paper and website.. expands the understanding beyond the classic view. I can see that the secondary flux field will be diminished beyond the shell because it has limited permeability; so the reason for the COP=8 and not infinity.  Also indicates that a higher permeability gradient between the shell and inner core may have higher COP. Thanks for the insight.
/Wayne
Magluvin
Hey Wayne
Was thinking of if the primary field is able to get through the shell, why cant the secondary.   Then I remembered the sec has its own core, of which will attract most if not all of the sec field. Also The primary is right on the surface of the shell, so maybe as fields build around a wire, the first ones to appear expand outward as new ones are created.  Either way, maybe the further away, as in the shell from the sec, the sec fields lines, that get to the shell, dont have the pressure to escape beyond the shell to cut the primary windings.
This is just thoughts so far, but i think its the right track. ;]
Mags
twinbeard
Flux will seek the path of least reluctance... :)
Magluvin
Quote from: twinbeard on March 25, 2011, 08:08:55 PM
Yep.   They been spanking us around all these years with these regular transformers. Same as piston engines. 30% eff
I have seen transformers that have the core laminates welded in areas around the core. Thats just great.  make and insulate the laminates to reduce core losses, then just weld across to connect them again.
Ive also seen where the windings are separated instead of on top of one another, and between the windings, more smaller stack of laminated core material magnetically connecting the outer cores to the inner core, between the windings.  More eff losses.  Crazy
Mags
