The Gabriel Device, possible COP=8
Started by Feynman, March 22, 2011, 04:07:09 PM
forest
I hope you are all on the same hemisphere. :D Read Steven Mark notes. Thank you.
Magluvin
So does this mean that all we have to worry about is getting the primary field in?
Maybe when winding the primary, for each turn make wider spacing. This way you can go around the outer shell many times. You can make taps on the primary to make fast adjustments and still be covering the whole shell with powered primary wire.
Naturally it should be wound with more wire than prescribed just to test those boundaries while your at it. Then when you find the sweet spot, cut off the tail.
Hey Mav
I like the idea to us an audio amp to try driving frequencies, with adjust abilities. You can use pc or laptop for a signal gen to the amp, and try different wave forms.
I have an old Soundstream D100 and a Class A 100 Im setting up for this kind of testing.
Hey Forest
Any particular notes we should pay particular attn to?  ;]
Mags
importfanatik
Quote from: e2matrix on May 01, 2011, 01:20:31 PM
If I understand your question right that was covered in post #303 and #304.  I had asked about winding direction a couple posts back from that too.  It's Counter clockwise.  Not replicating here yet but I'd like too when I can afford one of the cores.  I know wayne and casman have been working on replication and a number of others too.
Sorry, i totally misunderstood what he said about from inside to outside. I get it now.
I just tried using the inside coil as the primary and got 1.9VAC on the outside coil.
120VAC input on Outside coil = 12VAC output on Inside coil
120VAC input on Inside coil = 1.9VAC output on Outside coil
Where inside is 304 turns CW, and outside is 80 turns CW
forest
Quote from: Magluvin on May 01, 2011, 03:00:11 PM
Hey Mav
Hey Forest
Mags
Mags
Steven Mark device worked only in one position but when turned down side ceased to generate excess in output. He said that on Souther hemisphere his device worked "opposite". I think you see the correlations.
e2matrix
Quote from: forest on May 01, 2011, 03:32:20 PM
Mags
That was only on one of his early devices.  Later he figured out something that fixed that so they worked either rights side up or upside down.
