The Gabriel Device, possible COP=8
Started by Feynman, March 22, 2011, 04:07:09 PM
Magluvin
Quote from: Mavendex on May 18, 2011, 11:35:05 AM
I got all the but 6 volts to be reactive power so technically we have 6watts  in and 108watts out atm. I keep stepping it up and it keeps getting better :)
Mav
Hey Mav
Good stuff.  Im not sure what your last post meant by 108 and 108.
Are you still using the amplifier for input?
I have been doing some tests with the multi core, but I need a scope. I have a RS probe scope but its not a very detailed view. Was looking at scopes a while ago, but waited.  This is what Im looking at now. It is the next gen pocket scope from Arm. I like it.
http://cgi.ebay.com/ARM-DSO203-Nano-V2-Quad-Pocket-Digital-Oscilloscope-/280658851796?pt=BI_Oscilloscopes&hash=item41589237d4
Keep on keepin on Mav. Glad to see you check in periodically.  Be careful. ;]
All,
We are all anticipating progress. It will take time. It will take time to get rid of the toaster. It will take time to make determinations of the hows and whys.
Im glad the critics are rare here. Its refreshing. ;]
Mags
Mavendex
108 watts from the wall, 108 watts from the secondary with a PF from the wall being .94 is what that means
5 watt gain.
But again how much of that 108 watts is real or imaginary from the wall, 6 watts are real the rest is imaginary.
nope I was using a couple of toasters in parallel that only drew .9 amps total I couldn't get it to draw more if I tried, If I put my voltage probes in the surge suppressor it read 6 volts the Va on the kilowatt meter read 116.
My total input from the wall was 122 volts .9 amps so resistance wise I was using 6 watts and 116 volts returned to the source.
Can't debunk something that works :) Everything I have read about reactive power says it gets reflected back to the source so yay for us :D
Mav
importfanatik
No luck using an inverter and a 12V battery?
casman1969
Hey Mav,
Hep me here... 6V @1A in? Am I reading that right? Then 108 and 108. I'm not critical just trying to follow what you are saying since it sounds as if you're having positive progress.
BTW did you insulate between the halves of the steel doughnut and what material are you using for your secondary core? AWG of inner and outer? Secondary dimensions and turns on it?
Man, now I know what it feels like to pester (lol).
Keep it flowing Mav...
casman1969
And then, of course, you answered the in out question before I hit reply. Gotta love it.
