The Gabriel Device, possible COP=8
Started by Feynman, March 22, 2011, 04:07:09 PM
0 Members and 28 Guests are viewing this topic.
Hope
Looking for materials to build Thanes device as well.  I also think full core encapsulation is the most efficient way to capture all the output from the primary.  We waste so much freed energy.  Good thinking all!
Cheap4All
I've been looking at this vid on YouTube:
http://www.youtube.com/watch?v=UfBcYyr0fWI
A very interesting concept and a bit of a mystery as to how it continues to work after the battery is disconnected. Once the ruler is connected it becomes a closed continuously working loop, broken only by the removal of the ruler (but as is evident, not instant disconnection, just a slow magnetic decay).
Why is it doing this ?
But more importantly could we possibly glean something from this experiment that may be useful in the Gabriel Device ?
Your thoughts please !
Hope
This PMH is showing the OTHER side of "Flow" not found in our school textbooks any longer.  What they leave out is like a compass to what we should be paying attention to!  But remember magnetic flow is in 90 degree opposition to electrical current flow,  (what ever that means) according to Walter Russell.  AND he also states that bar magnets have 4 pairs of poles not just one pair.    Can anyone attempt to clarify what he means please?
Mavendex
Quote from: Hope on August 19, 2011, 07:10:22 PM
Mavendex please do not close loop ANY OU device without going through a regulator.   The cascade avalanche will destroy the device so quickly it can't be stopped.   Why would Permalloy shell be better?  If we saturate it and the inner core, won't the Permalloy act like the inner core and keep lots of the field?  Does anyone know if those shiny rock shaped magnets will work in the secondary core.  Crushing them is OUT.  They are way to hard to even break one with a 5 foot 60 lbs iron bar.  I looked like that dwarf in Lord of the Rings trying to break the ring with his axe hammer.   LOL
But I can make a magnetic ring of these rock magnets and seal them in resin. ??? Any ideas on this??  Should we try a camelot ring minus one magnet?  This will create an imbalance which spins into a magnetic vortex naturally.   Dave what do you think about this idea.  Anyone else that has tried this let us know ahead of time on your results please.
Tell me about it that when you close the loop that it will smoke everything... need to just run a charger back to the battery me thinks, got input power down significantly!like 150 watts total no power factor :) but I broke the device after inputing more than 10 amps which is sadly alot of work to take apart and put back together good thing I have more than 1 core :)
Permalloy will saturate faster than steel, permalloy is easier to magnetize and get a 2 Tesla field going. but I figured out a way to doit without the permalloy.
Hope
My meaning on closed loop was that you meant sending the output directly back into the input without regulating it. On any working OU device that would cascade the ouput into extremes.
