The Gabriel Device, possible COP=8
Started by Feynman, March 22, 2011, 04:07:09 PM
Magluvin
Hey Mav
0pf?   Do you mean capacitance between the shells, or the windings?  ;]
Thanks for helping here  ;]
Mags
Mavendex
Quote from: Magluvin on August 22, 2011, 12:42:57 PM
Hey Mav
Mags
0 Power factor when underload :)
SchubertReijiMaigo
Thanks for precision, I will try this.
I have made some test with the amplifier, and look like when I use more turns at primary and low frequency (down to 30Hz) the light bulb is more and more bright (input was 24 Volts)...
It's curious also that we must isolate the two half look like a single shorted turn that disrupt the correct operation ?
About this my shield was very hot !!!
Mavendex
Quote from: SchubertReijiMaigo on August 22, 2011, 02:45:22 PM
Ya thats what happened I learned the hard way after about 5 times of rebuilding that they have to be isolated from each other. the eddys keep that magnetic field close to the skin of the shell as well so all the really good flux is right next to the shell. even tho it all gets fluxed cause its inside of the shell the really really good flux is right next to the shell.
Hope
If we pore our own mold and make the material low saturation in the middle core(s) area(s) and high saturation at the rest of the cores we should be able to make your configuration plausible Steven. Maybe we could use three cores with the middle being low saturation and the outer high saturation.  I would think a core stacked model would be more efficient though.   I see a new material to block magnetic fields has been developed,  it will make cancelling back EMF easier unless we just use Thanes Hein's method to use it to our benefit (which sounds best).   Old Man Lenz is out of the law business it would seem.
http://peswiki.com/index.php/Directory:Perepiteia_Generator_by_Potential_Difference_Inc   explains how this works very well and we can all use this WORKING principle to build on now.
And the steel shell halves MUST be TOTALLY isolated from each other AND the windings.
