The Gabriel Device, possible COP=8
Started by Feynman, March 22, 2011, 04:07:09 PM
Hope
Has anyone found a cheaper source for these nano cryst. 10nm cores? AND the credit for the nano ultra sheets is kinda Jouleseekers leading.  He said he had a Goldmine core to share so I researched there catalog and found the sheets there.  They must be going fast, because a week ago they offered 100 sheets for $500. carton lot.  Singles only now, so if you want some anyone I would grab them asap.
Your welcome all.
I still have not ordered my cores, was waiting to see if anyone needed to order with my order to save big bucks.  I will be getting a couple of M-616's or equivalents soon.  We can order together and get drop shipment to our own addresses.  I been busy with a service project and will be able to work on this evening and Saturdays a bit.   Winter is coming and have lots to get ready.
Mavendex
@ Mags, Yes the thinner shells seem to boost voltages quicker but thats as far as I have gotten on that, my turns shorted out do to being overworked so had to order new wire. I probably put 3 of these together a week to figure out certain variables, and where the best output can be found.
So far I can pull out 600 watts out of the 2000 turn 16 gauge innercore which is pretty close to the 6000 turn 14 gauge innercore.
and the 21 gauge I could only pull 300 watts as max output.
not trying any tricks or anything just straight 120 volts 5 amps or a 600 watt load.
Differences:
21 gauge core, helical wound, 6000 turns, and a 250 turn 9 Gauge Primary
Max output - 300 watts - 15% efficiency
14 gauge core, helical wound, 6000 turns, and a 378 turn 9 Gauge Primary
Max output - 600 watts - 76% efficiency
16 gauge core, geometrically wound, 2000 turns, and 400 turn 14 Gauge Primary
(Note)If it was a 9 gauge primary I would get about the same watts out with much less input and would drive up my efficiency.
Next item up for bid, 2000 turn 12 gauge, geometrically wound with a 400 turn 9 gauge primary, I expect to get much more than 600 watts out of this guy for just about the same price.
Wire pending arrival t-minus 6 days and counting on the 12 gauge.
@Cheap, whats with the cry face? and your welcome?
Hope
Thank you Mavendex,  your notes are useful.
Just read about nano wire proof on duality of light and it makes a question about decaying matter that may mean all matter has duality.  Which is like north and south poles.  This would explain how John (the unique) Hutchinson made metal bars twist and bend apart and dust of nano size.  He was causing the atoms to reverse charges and repel against each other atom.  So like Ed Leedskalin proposed everything IS magnets.  Then what happens if we apply this to current?? Can we make these charges repel the atoms in the current chain and then when we stop the effect and they start current again.  If this current carrier is causing induction then the pole disassociation will also cause a type of current flow in the induction.  Switch this on and off and we have current without going to ground.  Hope you can follow this logic it means it is a way of releasing atomic bonds using only pole flipping.  The conductor could even be inside a glass tube vacuum and the pickup coils outside the tube.  Magnetic fields in motion and frequency seems to be a key element.  I only am writing this to lend a thought to what maybe happening with the Gabriel device influenced by the phase shift.  This would or could cause a momentary realignment of poles in the electrical charges and this flux COULD add up to the additional energies gained.??
Jack Noskills
Has anyone tried primary windings using same method as Tesla used in his patent 381970, System of electrical distribution ? Divide primary into four quadrants and put 'positive wave' through two opposing quadrants and 'negative wave' through other two. This way Tesla added rotation in the magnetic field.
You would need to use two diodes to separate current in two parts.
You can find the patent from here (search for 381970): http://www.free-energy-info.co.uk/Chapter5.pdf
If someone is not familiar with this site then it is worth checking out, ABC of free energy stuff. You should read also Chapter3.pdf, about solid state systems.
SchubertReijiMaigo
[HS ON] @ Jack:
You read in my mind or what !? Since it's seem that Tesla look alike device seem to produce FE (Gabriel device is a good example) I have read all Tesla patent in solid state transformer generator,etc... I have studied this generator 382.282 with his four coils... It look like a TPU of Stevan Mark... I have made simulation with coils plugged like the patent (did you notice they are connected in a weird way ?) This device did not produce a rotating magnetic field like a motor but EM pulse when the two phase are in opposition polarity...
I guess this converter produce energy not by transformer action (output is not sinusoidal but rather pulse like I said above... Maybe it can be FE also...
Remember that Tesla does not speak to FE in his patent always hide it !!!
I have a big CRGO core but this device need a two phase at 90° driver, I don't know where  can find this...
[HS OFF]
@ Mav: congratulations, for this experiment !!!
1) It seems that increasing turns, increase power.
2) Reducing thickness shell also... Mine is about 1.5 mm, I wonder with 0.1 mm what the result it would be, hmm... !
3) Good to know this for later version.
4) I wait always about my 2kg 16 AWG wire, so I can't replicate at this time...
SRM.
