The Gabriel Device, possible COP=8
Started by Feynman, March 22, 2011, 04:07:09 PM
JouleSeeker
Quote from: Hope on September 02, 2011, 02:11:13 PM
Jouleseeker:  please, could you share the supplier of those cheaper ultra cores you mentioned.  I am heavy on researching correlations and this takes me all over the net.  But still I have not found a USA source to ultra sat. cores with a value pricing.  I will study the formulation they use and check the data specs with respect to Magnetecs offerings and give the forum the straight scoop on it.  We all seem anxious to get started with a build.  I still think a rod inner core wrapped with 4 sections of pipe (split 4 ways) will allow us to phase each pipe section, squeezing the electrical/magnetics to respond differently than any device presently on the market.  These nano ultra SHEETS could be used to line or cover the pipe in different ways or just wrap the secondary in it as the core covering then wrap (wind) the primary over the sheet.  (This may prove to us that the steel doughnut is not needed).  that way we could add all the windings we want to the secondary and then just wrap it with sheets split to sections or spirals to cause the phase shifts.
Hope:  http://www.cwsbytemark.com/index.php?main_page=index&cPath=247
I ordered the CN100-80-20G, 100 mm OD, 80mm ID -- but they were out of stock, 5 week delay.
JouleSeeker
Hope:
QuoteThese nano ultra [high-perm] SHEETS could be used to line or cover the pipe in different ways or just wrap the secondary in it as the core covering then wrap (wind) the primary over the sheet.
Right...  I like the idea of cylindrical geometry also, and the use of the high perm sheets.
  About the M-616 from Magnetec, pls let us know the price, would you?  I would really like to buy one of these, if the price is decent (<$250 about).
Mavendex
Geometry wound on the primary increased efficiency by 30% :) with 100 less turns.
t-minus 3 days till we get the 12 gauge, secondary 5 days till we get the 10 gauge primary.
Mav
Hope
I will just post this modded Bedini from the YouTube due to numerous requests (lots of you want it so here it is).  I never have seen so much HHO made from 52 volts at 800Hz and only micro amps.  This guy is on to something with this auto resonant matching circuit.
http://www.youtube.com/watch?v=4l1PfmTheFM&feature=autoplay&list=ULHx7aWaPbBo4&lf=mfu_in_order&playnext=1
http://www.youtube.com/watch?v=Hx7aWaPbBo4&feature=bf_prev&list=UL4l1PfmTheFM&lf=mfu_in_order
BE SURE TO USE A TRANSISTOR FAST ENOUGH FOR YOUR LOAD Matching. and don't operate without a load.
Hope
When high pressure systems and low pressure systems meet lots of energy is released.  Can this be simulated with our Gabriel device, perhaps phasing is doing just this very thing.
What do you all think?
How can we make this happen with intent? Is this what happens in a Bifilar winding??  Can we drive a bifilar winding with two mixed signals like nature does??
Signed  "Sleepless near Seattle"
ps  THIS new topic may interest you all.
http://www.overunity.com/index.php?topic=11370.msg299480#msg299480
