The Gabriel Device, possible COP=8
Started by Feynman, March 22, 2011, 04:07:09 PM
Jack Noskills
One comment about this quadrant phasing using diodes. When one quadrant conducts, it will induce voltage also in the idle quadrant that is now blocked with diode. But it does not stay there, so I was thinking maybe an AC capacitor in parallel with coil to capture it and when voltage drops as sine wave starts to go down this stored energy would come back as blocking diode would begin to conduct. Capacitor should be big enough to store energy but I quess any size would do for testing purposes. Two caps would be needed, one for each coil.
From secondary point of view it would first see flux coming with certain intensity and when diode begins to conduct flux intensity would increase. So now field would be rotating and increasing in density with time. Maybe worth a test drive ?
Edit: direction of quadrant windings could also play a role here and should be taken into account. If two quadrants begin to conduct at the same time their fluxes should be in the same direction in order for secondary to see anything. And while cap is being loaded this would mean there is current going in idle quadrant until cap is filled ? How will secondary react to flux from this ? hmm, maybe there is opposing flux in some time instant no matter how quadrant is wound.
Mavendex
I don't think it matters as long as its over 100% right? Geometric shapes like the 64 different polygons have different outcomes. Like I said 100 less turns and a geometric shape had a 30% increase in output, I even took off a few more turns to see where we where and it dropped back down to 76%, so that tells me the reaction was just beginning so adding turns would increase output by some factor.
Timing of the coil can be modified thru geometry, because each turn will fire in order thus pushing the field around.
I do think that some electronics IE, caps resistors or diodes will enhance the project, its worth a shot but ill get in to it after I get this next one made.
Mav
Hope
If you want a vortexing magnetic fields it is much easier than phasing coils.  Gaped torrid coils will cause magnetic vortex spin as will just magnet gaped coil.  See the Green's Camelot motor for information and proofs on this at this link.
http://www.youtube.com/watch?v=hkgyY47duCM
Then if this is needed we could place pickup coils in physical paths of magnetic spins and harvest it.
If you make a Camelot ring perhaps filling in the empty space with a quartz piece wrapped as a pickup coil and placing a load powered buy these coil ends will allow use of the vortex.
Mavendex
Quote from: Hope on September 06, 2011, 08:20:08 AM
Yes, but phaseing the coil is part of the process, Ethier with electronics, or geometry or both, getting the field to move around in a smoother, more powerfull motion inceases your turn around on the pickup coil, like our secondary which is our pickup coil.
If your #1-36 turns are every 10 degrees around the 360 degree toroid then your #37-72 turns will have a diffrent phase in them cause it takes time for the power to cycle thru the turns each turn has a diffrent phase, so the trick I would suspect and its just a hypothesis is getting the field collapse to happen faster by aligning your turns to reflect something of what jack said about the electronics.
so if have 9 turns in every ten degree mark, then the power will have to travel around 9 times around the core to get to back to the number 1 turn and start the cycle over again, or sinewave, verses helical which would just be 1 cycle thru 360 turns.
Hope
Alright, now I understand this vortex.  Can't a gaped coil pulsed with dc make a strong magnetic vortex as well.  Then a overlaying gaped coil pulsed with the opposite DC charge at the same time should be able to attract this first coils field up, right?  The gap on the secondary may have to be either near the first gap or 180 degrees out.
And please tell me what a gabby is?  It is a term we don't use in the USA except for someone (like me) who talks a lot.  OR Gabby Hayes.
