The Gabriel Device, possible COP=8
Started by Feynman, March 22, 2011, 04:07:09 PM
the_big_m_in_ok
Quote from: AmericanMan31 on September 06, 2011, 03:17:37 PM
HOPE     ...
     Whos to say the secondary coil isnt an antenna, I mean ..it certainly is picking up aether-like energy in an unknown fashion, right? Antenna!--viola.
Well, since my focus is mainly on theoretical research, and patents are easy to access, and that some patent approximately follow what is currently being studied, take a look at this:
http://www.google.com/patents?id=uhU1AAAAEBAJ&printsec=abstract&zoom=4#v=onepage&q&f=false
(Fig. 14 on pg. 5 of the patent has a device which arguably wasn't designed to be OU.  I encourage all readers to continue looking for ways to tweak your designs until you can't go further or else find your answers to your questions.  Tesla patented some of his currently investigated designs on this site, so there's potential to be uncovered by experimentation.)
--Lee
Hope
OK Lee  your right.   I got a clear picture of what is going on with this natural sea of energy now.   Everything has a natural cohesion to like atoms (similar to water surface tension) But all wavelengths have it.  So when we disrupt it, it re-balances using it's own energy.  If we disrupt the electrical properties say using voltage spike (the higher the voltage the more energy types it disrupts, the more the potential differences the more the disruption).  Like the bigger the rock we throw in the pond the bigger the splash and no only in the water but splashes on the shores too.  So all we have to do to use this natural re-balancing energy which is coming thru the air (bad conductor) is provide it with a good conductor that doesn't become saturated (we have an antenna that is attached to a load which provides a path that is less resistant than the air) if it does become saturated there is no potential difference and the flow stops using it, and uses the air again or another less resistant path.  So HV disrupts the cohesion, this imbalance is a potential difference.  Nature flows to balance the potential difference, we make a path and work to keep this path less resistant than the air.  BINGO we get to use natural energy (of course we may have to keep the spark gap going to keep disruptions causing a potential difference).  Perhaps just the loads draw can keep it flowing??  Now this is how it is done and I believe we can all make devices using this principle.
the_big_m_in_ok
Quote from: Hope on September 11, 2011, 03:36:08 AM
OK Lee  your right.
@Hope
Concerning the rest of your post:  I hadn't thought of the OU process like that, but I think I understand a majority of what you said.
I do mostly low voltage experiments of a simple nature (as I understand "simple") on my research Bench at the bottom of    www.OverUnityResearch.com .
                                      (The Bench has the same name as my handle here, namely,  the_big_m_in_ok.)
I myself am looking for answers, just like the Members here.  Keep at it.
--Lee
Hope
So can we use our ultra perm cores then to conduct the re-balancing natural energies.  Why not just spark gap and disassociate the cohesion fields of the surrounding natural energies?   (I know, I know try it and see) but I wanted to gain from others experimentation to accelerate the project development.  I really like having a load on the secondary side to keep saturation from stopping the flow of that which we may be gaining.
nul-points, thank you  for your direction and willingness to help all us here.  And you Mavendex for your assistance in leading this topic.  Are you NDA hampered or can you share all you know?   Can you now explain more concisely how the device is working?
Steve do you see this secondary as attracting natural energies or phase compressions from the primary?
Mavendex
Quote from: Hope on September 11, 2011, 10:23:31 PM
Its a open source project I share mostly what I know and how to tweak it cause I build them, Im not a EE, or a PHD, I ask questions like everyone else but more or less I end up having to learn on my own. There is no NDA its my invention that I have shared.
