The Gabriel Device, possible COP=8
Started by Feynman, March 22, 2011, 04:07:09 PM
Mavendex
My progress is steady, finally got all the reflections out of the device for high power outputs. Found out that if you stack two nanoperms and put the machine together you get a cancellation effect making a 0 output either way you charge the device which was very interesting. So I took it out of balance and am getting perfect results, IE no voltage drops on the secondary while loaded no reflection in either amps or power factor while the secondary is loaded, all Im doing now is boosting my voltages on the secondary atm to see how high she will go.
No sweat right just takes a little elbow grease and a can do attitude.
"Think for yourself man, don't do like they do, its a sick world you just gotta stay true, stay true and everything will be cool. You gotta blaze your own trails and make your own rules." (Kottenmouth Kings)
Cheap4All
Quote from: Mavendex on September 28, 2011, 10:25:38 AMFound out that if you stack two nanoperms and put the machine together
Wow !...great to see someone is trying my idea a while back of using two nanoperms together. I take it by 0 you are meaning nil results rather than a power factor of 0 ?
Quote from: Mavendex on September 28, 2011, 10:25:38 AMSo I took it out of balance and am getting perfect results
This is great news !  I take it that this is still using the two nanoperms together ? Could you elaborate on what you mean by taking it out of balance ?
Mavendex
Quote from: Cheap4All on September 28, 2011, 04:48:34 PM
Wow !...great to see someone is trying my idea a while back of using two nanoperms together. I take it by 0 you are meaning nil results rather than a power factor of 0 ?This is great news !  I take it that this is still using the two nanoperms together ? Could you elaborate on what you mean by taking it out of balance ?
Ive been playing with multiple configurations to find the best route to make as much power as possible, according to some people by stacking the cores you increase your cross section and thus make more juice, well the initial try was a big fat fail cause I got 0 output in either direction, especially for about 1000 watts of input, and your are correct it was the output not the power factor that was 0. Although getting to a power factor of 0 is very very easy to do  :) Getting it to stop reflecting well thats the hard part but still easy to do once you know the secret.
Bringing it out of balance means that since we have 2 innercores on the configuration our primary magnetic fields = our secondary which is what created the cancellation effect, by adding magnetic fields to the primary I was able to increase the output again. Magnetic field ratios, Quantum Gearing, what ever you want to call it that's whats happening, at least one of the functions.
Cheap4All
Quote from: Mavendex on September 28, 2011, 05:47:25 PMMagnetic field ratios, Quantum Gearing, what ever you want to call it that's whats happening
Many thanks for the prompt reply. Its starting to make sense to me ;D. Increasing the size/area of the secondary field mean't changes had to be made to the primary. Thus by doing just what you have done, by increasing the primary to offset the new secondary, the quantum gearing changes.
BUT more importantly the results you are now getting clearly seem to be heading in the direction that you wanted from day one. So its really good that all your hard work is starting to pay off. I just hope I can emulate your same result by using 240v which applies where I live.
matthewklinko
Thanks for the update Mav
I just finished my coil last night and tested it.
Primary has about 200 turns and secondary about 2000 turns, 18 AWG
I tried various input voltages , but for one test.
I put 5V AC in at various frequencies from an amplifier.
The output voltage on no load is about 50V. And virtually no current flows in the primary.
When I put a load on, the voltage across the coil dropped, to about 5V on a 150 ohm load. and the current on the primary went up by 0.1A while on the secondary there was only 0.03A.
There was a slight delay of the secondary voltage compared to the primary , it was about 45 degrees, so not quite 90 degrees which is a power factor of 0.
Is there anything I am doing wrong?
thanks for any help
