The Gabriel Device, possible COP=8
Started by Feynman, March 22, 2011, 04:07:09 PM
Mavendex
Quote from: matthewklinko on January 05, 2012, 08:54:42 PM
Ok sounds good, any chance of getting a update how you are going with your project? investors?
I havent had much time lately to work on my replication but I hope to start back up again in a week or so.
goodluck with it all
Working on the Powerfactor 1 side of things I was told having pf 0 was impractical by a couple of engineers so I had to go back to the drawing board, Tapping in to the GMC Gigantic Magneto Capacitance to increase the potential/voltage of the device to exceed 100% with a powerfactor of 1, the design had to change a little but im still using a innercore and outershell just wrapping it a bit diffrent to get the PF 1, So far so good first time out I was able to achieve 75%, then I redid a couple of things and got to 99.7%, redoing my innercore to exceed 300 volts from 70 should give me the added boost im looking for and create more of a capacitance with my shell should have the transplant done over the weekend.
The Permalloy core Im going to attempt to make should get us well above this current transplant cause the magnetic saturation point of permalloy is around 2 teslas, vs nanoperm which is 1.2, although after saturation of the nanoperm I can get it to almost 1.8 got a nice little magnetic meter that lets me know how strong the field is, so if thats the case then I can drive the permalloy to around 2.5 or so teslas which will increase my voltage and possibly current not really worried about the current tho.
So im just movin along like donkey kong watching the last bits of football and bitch'n cause nebraska can't pull thier heads out of thier butts to make a decent bowl game. freakin huskers....
Mav
oh and here is the GMC info basicly is what we already have this is why when you dose the device with 1 or 2 volts the voltage goes sky high, by modifying the shell a little and having a extremly high voltage on your innercore which translates to the shell, so then you just wrap up the rest of the transformer with a secondary and a primary and walla, the really cool thing about it is that she is Super Silent the variac makes more noise than the actual transformer, and she runs at room temp virtually no heating.
http://www.greentrade.org.tw/backend/lession/doc/77/201188648.pdf
matthewklinko
Quote from: Mavendex on January 06, 2012, 12:31:47 PM
Mav
Thanks for the update Mav, that all sounds very interesting.
It seems that a Magnetic Capacitor could be a next type of battery, if its all true.
Yea a power-factor of 0 isn't that useful it still has the same amount of current in the cables, though you could get free electricity to your house if your service provider doesn't charge you for reactive power?
What I don't understand is the percentage values you are giving are they input power to output power? or voltage?
Does that mean your current device with power factor 1, still giving you the overunity effect?
I'm guessing that if you are running at room temperature that means no more shorted turns.
So if I understand your current design correctly, the shell is your magnetic conductor (two halves) , the air inside is the dielectric, and the primary supplies the external magnetic field. This makes the magnetic capacitor, then if you apply a high voltage to the two halves?
And the secondary core/coil, taps this energy?
Matt
Magluvin
Mav
Was thinking.  If you used a cap to make the primary an LC, and find the resonant freq, and tune the input to that, your input should be lowered considerably. And if the transformer works the way I think, the secondary shouldnt spoil the primary resonance.
Worth a try. ;]
Mags
Cheap4All
Quote from: Mavendex on January 06, 2012, 11:27:09 AM
so ya you can melt it down and cast it, its just a alloy of Iron and nickel
I hope it can be done as you state. If it works its certainly a good way of getting some permalloy quickly and easily. Look forward to seeing what results you get after your first casting  8)
Mavendex
and the transplant worked ! more to come!
