The Gabriel Device, possible COP=8
Started by Feynman, March 22, 2011, 04:07:09 PM
Mavendex
Quote from: Jack Noskills on February 01, 2012, 05:43:20 AM
I have been thinking would it be possible to use gabby as a resonant transformer. Problem with resonance is that point of resonance changes with load so you need to always tune it to output, or make the output part so that it does not affect input. I recently read article about harmonic resonance in trafos. It was said to avoid it at all cost, why ? Because at harmonic resonance total capacitance and inductance of the system is equal and their sum is 0 (inductive reactance and capacitive reactance point to opposite directions if you think of them as vectors). What is left is only ohmic resistance which means current can flow freely in system creating mucho power which eventually burns the trafo in seconds when harmonic resonance occurs. Thats free energy right there.
Resonance occurs naturally in LC tank circuits. If your input frequency is not in the resonance point then more work is needed to get the power out. There is self inductance of primary and secondary that slow things down. Trafos in general work like this, you got lots of wire in primary around a core. So much that self inductance almost prevents current flow, little flux remains in the core. When you connect secondary to load current starts to flow in it creating opposite flux and what does it do to primary ? It creates more current in the same direction with the primary which reduces primarys self inductance. This in turn allows more current to flow in primary, costing money.
So self inductance wastes power and is bad. Resonance is good as it keeps oscillation ongoing at little effort, power is used only to overcome ohmic resistance. Resonance can be achieved easily with gabby as secondary does not affect the primary. Can anyone do some experiments to find resonance point ? You would put caps in parallel to primary and increase frequency of signal generator until little current would flow, this is the resonance point. All the action would still be in the primary, but current would not flow through it, current would flow in it. Then you add some load to secondary and resonance point should not change. Next you would need to add more turns or more caps to tune it to 50/60 hz. Once there, you got yourself resonant transformer which is always OU.
I try to do experiments with avoiding self inductance. I got small nanoperm core around which I am wounding caduceous coils. Caduceous coil resonates at all frequencies and it has zero impedance according to radio men. Maybe there is no effect at 50 Hz but will try it out still. I have currently wound 180 meters of wire around 63 diameter nanoperm toroid (80000 perm). Things proceed slow but steady, I will make some tests when I got 300 meters wound. I have other normally wound toroids using same amount of wire so I can compare them. I have blown my meter so I will use light bulbs from now on and other non scientific methods. That was my second casualty in OU war, lol.
My idea is that self inductance would be positive with caduceous type wound. Instead of choking input it would accelerate it as self inductance now always adds: adjacent wires always go in opposite directions so when self inductance occurs it does not go against current but adds to it. Maybe this would work in gabby too, but I see that there are other routes going on which seem interesting.
Thats what a ballast is for you can pick them up at Menards for 30 bucks, I get them for free cause well Im me :), you still need the drop in pressure to get extra electron spin just like a old style vacuum tube, seal the shell with dielectric and the two halves of the shell become the magnetic cap. a interleaved or Vortex winding is prefreable like I have explained before in previous posts,
Wonder where you got those cores Im sure I know where you got 1 of them!
Mav
Mavendex
Cadacus and time manipulations sound intresting also the cadacues looks like a royal pain in the behind,
I have gotten a 2ft rodin coil to jump a bench and it self on a 240 -40 amp input, vortex winding is much the same as cadacus, the winds are seperated to not include cancelations, a 10 degree 5 degree and 3 degree seperation allows for extreme voltage out with out the heating cause by conventional winding as well it sweeps better towards PF 1 than conventional winding.
Sorry I haven't gotten a video up yet after I posted last week all hell broke loose at the church I work at seems someone feels the need to hack my wireless make a clone of the server and then make life ever so demanding on my part, problems solved tho. (Much ass kickery involved)
I am rounding out the last few turns on the device after this post and hope to have much good to report things are looking good although I fried a couple of ballasts, good thing they are free.
I haven't hit a point yet where she doesn't return more power out with less power in with as many turns as I have now, which is sweetness, she switches from quite to load at certain voltages a resonance cap if you will as you add more turns the cap gets a increase in voltage and decrease in amperage as one would expect (secondary gets a increase in power out to equal that of the diminished amperage in on the primary which is what we have been looking for) normally there is a spot where it does no good to add more turns but on this particular config it just gets better and better and better.
many weird things afoot I plan to document and should prove to be a nice kicker for conventional theory to prove.
Mav
Jack Noskills
I am using M-088 from magnetec. At the moment I am not planning to use a shell, just wind and wind. I divided the windings in the core in two halves, A and B, and now I have 10 layers of caduceus winds ready. So it is kind of experimental core, lots of wires coming out and to reconnect, 20 pairs. Now I can play with different layers, or sides, or both. It is like the Tesla rotating magnetic field trafo patent, but I am using two segments instead of four, because the toroid was too small to get 4 segments.
Idea came to my head last night, if I connect both sides together using a capacitor and charge one cap, would it self run ? Energy would be sloshed between two caps and energy would continually increase. Caduceous wind gets rid of self inductance, maybe thing would resonate. E-fields of the sides must oppose so when current runs in one side, it creates flux that creates current in the other side in correct direction. Difficult to explain properly but if this works I will draw a picture.
Quote from: Mavendex on February 01, 2012, 11:40:53 PM
Mav
Again, looking forward to it more so now seeing how europe is being raped by a cold wave reminding us or me at least why I'm into this stuff :p.
matthewklinko
Hello Mav, and all
I've been away for a while for work and was re-reading the progress and catching up on the info.
It sounds very interesting and the progress you have made in one year is overwhelming.
Just wondering how the video is going on, it would help clear up a lot of misunderstandings,
thank you so much for all your work so far in this field and I hope to be able to follow in your foot steps one day.
Matt
