The Gabriel Device, possible COP=8
Started by Feynman, March 22, 2011, 04:07:09 PM
Mavendex
Thestone
Quote from: wayne49s on March 23, 2011, 07:13:28 AM
I've been looking a bit more in detail how the device is suppose to work, and I don't believe this device works according to Thane's approach. To avoid the BEMF to the primary, Thane's approach was to move some of the magnetic flux from the secondary to a separate core (the secondary core). This requires that the secondary coil be wound over the 2 cores as pictured above. If you look at the Garbriel device, it is exactly the opposite; it is the primary core that encapsulates the 2 cores concentrically. According to Faraday's law, the magnetic flux from the secondary coil will impact and generate a BEMF in the primary coil since the primary coil turns are wrapped over the secondary core also.
If we were to apply Thane's approach to the toroid configuration, the primary and secondary coils would be switched (i.e. the primary on the inside toroid), and the higher permeability core on the outside also. In this way the outside secondary core would absorb most of the secondary flux and not impact on the interior primary coil to generate the BEMF.
Assuming we can replicate the results, it may be a lot tougher to explain how the device works, lol! If anyone sees something wrong in the analysis, let me know.
/Wayne
From my point of view all these devices are trying to duplicate the principles on the "Saturable Reactor".
The Stone.  :)
verpies
@rfmmars
David Klingelhoefer is the original inventor of the Gabriel Device, right?
Is this device non-working or a fake?  There is a big difference...
Can you elaborate why you think so?
@anyone else
Did anyone measure larger power output than the power input, on the Gabriel Device yet?
If yes then how was this measuremnt made?
Quote from: rfmmars on April 21, 2012, 08:49:06 PM
Yes here's the best update
David Klingelhoefer, RemeroUK= FAKE
Cheap4All
@Mav.  Its great to see you back, but by God you make me a nervous wreck watching your vids with you playing around with those live wires like that ! I don't know how you have the courage !!
No wonder a while ago, I thought you may have blown yourself up. If I had only known what you were doing with those live wires back then, I would have had even more reason to think that.  :o
But it seems like you are having great success which I am ever so pleased to hear because we sure do need a product like this. So am looking forward to your next update/s with great keenness.
@verpies. I don't know who you are, nor have I seen you here before, but what a damned cheek you have coming in here and chucking your weight around like Lord Almighty.
I suggest you stay away if that's the way you are going to carry on.
