neptune
@Webby1 . The effect that you describe will no doubt work . The question as ever, is if it is OU or not.
@ OK so the fabrication of [2] is more complex than I at first supposed, and will be correspondingly more expensive .Cylinders will have to be made to specific dimensions. So we really need some input on dimensions and proportions from Mr Wayne, to justify the expense .
LarryC
Quote from: mondrasek on June 08, 2012, 11:58:15 AM
If you read the patent carefully you will find in the last few paragraphs that it is possible to move the *water* between the Zeds instead of the air to achieve the same switching of the power units.  This is the current way Mr. Wayne's team is going.  It is more efficient.
I'd like to point out that Fig 5B shows that the liquid gap is filled to the top when just 10% of the water is pressured out.
Fig 15 shows that all of the water has been pressured out, so now if the pod rose of 10% of  the fill distance then there would be no liquid gap and combined head, which would upset the whole process. Since it is a container, it seems to require that water has to be pumped in to that container to reach the results in Fig 18. In his pictures on his site of his patented device, the water pumps on top have flexible piping running to the bottom of the tanks.
Regards, Larry
mondrasek
@mrwayne, is the precharge method for introducing the air through the pipe into the pod (to pressure balance the static system) exactly the same when you are setting up the system to run by exchanging the water vs. exchanging the air?
Thanks,
M.
mondrasek
Quote from: markdansie on June 08, 2012, 10:38:54 AM
Hi
Just to get the record straight, from what I have seen Mr Wayne has something from early tests I saw. However before i sign off on this one It has to be subjected to a continuous two day non stop test, and then be subjected to evaluation by a team of engineers and scientists.
i am impressed with the people involved and the community spirit in which it has been developed.
Time will tell if the device will be proved out but all the signs so far is indicating they may succeed.
Kind Regards
Mark
Mark,
If you are allowed to tell us, what is Mr. Wayne's team's next step?  How do they go from where they are now to agreements with Siemens, GE, ABB, Hitachi, etc., to start replacing existing nuclear reactors and fossil fuel burning electric generation systems with this new technology?
Thanks,
M.
Cisco
Get it from the horse's mouth (no offense, Wayne) during yesterday's interview with Gary & Mark on Smart Scarecrow. Wayne comes on soon after 1:13.
http://www.youtube.com/watch?v=rMda6OUOYRw&feature=player_embedded#!
