Thanks to ALL for your help!!
Build a Moray-like device
Started by Ros-Co., May 28, 2006, 06:09:32 AM
Ros-Co.
Ok, but I think It's not a very useable system.  How many power could be generated?  Maybe few watts.  It's nice for demonstation, but not solve the energy problem.
I heard some information from my friend, who is a radio amateur, that his antenna produces sparks between ground and and center tap on the connector.   But only does it in stormy weather.
How a device catch the charge in nice weather?  From the ions of the atmosphere? It requires a very big surface collector area or not?
Bruce A. Perreault
The electret antenna gets its power from the wind. It is really a blade-less wind generator.
Yes, it is true that Moray did away with the dipole antenna but it was replaced with loop-type antennas like the ones in early am radios.
                       -Bruce P.
Ros-Co.
Ok,  I understand.  So It's an interesting wind generator :)
I heard some interesting informations.  But the inventor said the tuning, geometry, and ratios are very very critical.
Moray used special tuned circuits, to capture the energy.  First we need capture a synch signal from antenna.  That's why Moray use a detector
(I think its very similar to a pin diode)  Radioactive materials maybe activate the semiconductor, and decreases the detector treshold.
The synch signal helps to synchronize the higher power oscillator.
In my opinion, the impulse devices (eg. Newman, Bedini, Adams, Grey, machines)  generates a very wide spectrum of electromagnetic energy. And it covers the spectrum of the universe energy.  But I think it's unstable, and random effect.  But at higher power it generates useable amount of energy.
Ros-Co.
Bruce A. Perreault
The electret antenna and Moray device are two different animals.
It is too bad tha Stefan will not re-activate his yahoo list because this forum is to hard to follow. I only visit here every other month, if that.
                -Bruce P.
Ros-Co.
So there are total different.  OK.
Are there any better possibilities to keep in touch?
Ros-Co.
