W.K.Coombs Open discussion thread
Started by ramset, April 25, 2011, 05:32:07 PM
protech
Quote from: Bruce_TPU on April 25, 2011, 10:07:15 PM
Hi Bill,
I have learned over the years, that stick drawing visuals do much better than words...LOL
The project I am working on was the same, most don't listen well.  It is just the human condition I suppose.
But most are certainly willing to learn.  It is always funny when someone says they have replicated anothers work, even with pictures and diagrams to follow, and it looks nothing like the original, and then they moan because it doesn't work.  Sad, but entertaining, in a twisted kind of way!   LOL
Cheers,
Bruce
EDIT:
Dream think build,
I do not recall the man saying anything about magnets!  He said to put something at the ends to control the movement.  Get it working first before modifying.
and Bill, if I am wrong about the magnets, please let me know!  Thanks!
Think I just gave up,you can deal with me on pm guy ....... its so easy once you know ...........
AB Hammer
Protech
Here is a similar one from a patent application that you might want to know about. My good friend Preston was trying it out. Now yours is a base unit and the patent was a hanging unit but the basic concept has close similarities. Preston didn't have much luck but the information is there.
http://www.youtube.com/watch?v=eoWLuO9jSY0
And here is the Bessler wheel string that has a PDF of the patent application.
http://www.besslerwheel.com/forum/viewtopic.php?p=72455#72455
This might help with a larger and power producing build.
Alan
Alan
DreamThinkBuild
QuoteGuy you are so off base makes me wonder.........
Hi Protech,
I was just pointed out that you said 20" lever, the first design is wrong, I understand that now. Have you built your device? I just want to know one thing and that is how you overcame the twist in the platform on the rollers that is imparted by the pendulum swinging down?
Bruce_TPU
Quote from: DreamThinkBuild on April 25, 2011, 11:33:34 PM
Hi Protech,
Not to answer for Bill, but it sounds as if your weight is not centered/distributed properly on the bottom of your pendelum, if it is twisting.
Cheers,
Bruce
SkyWatcher123
Hi folks, Hi protech, thanks for sharing. So if it's similar to the video hammer posted, are you thinking of generators attached to the wheels or maybe magnets at each end of moving cart that interact with coils at each end.
How about something similar to Matthew Jones full rotating pendulum bouncer, though like this, we will not use full rotations, just normal pendulum swings and set the fulcrum on springs.
Then we use those one way zip pulls with gear type teeth on the strip and so when the pendulum swings downward, it will pull the zip pull, compressing spring and spin a generator.
Then as the pendulum swings upward, the zip pull will not be spinning the generator and the pendulum can freely swing upwards to again reset the zip pull generator. Just a few thoughts.
peace love light
