W.K.Coombs Open discussion thread
Started by ramset, April 25, 2011, 05:32:07 PM
protech
Quote from: nightlife on April 27, 2011, 08:29:48 PM
Come on already. Enough with this foolishness. If you had a working model, no one would be disapointed and I really wish you did but it is impossible to have a working model as you have discribed. There is to much resistance for it to even be just perpetual. The added picture shows resistance points that must be overcome just for it to be perpetual not alone produce anything.
oh i love this you have no brian at all ...and if you do and aIm wrong do overunity
Bruce_TPU
Your drawing is not even close to what was described-  FYI
vonwolf
Quote from: ramset on April 27, 2011, 07:29:13 PM
Protech
Sure is a lotta luv going around!
Being "blessedly free of the ravages of intelligence"
I'm having a hard time figuring out your PDF.It could just be my handicap
getting in the way [dummy stuff]
  Will you be sharing anymore "how its done" ?
Thanks
Chet
HI Chet;
  what pdf are you referring to?
   Thanks Pete
ramset
Pete
When Bill [protech] first started "sharing" He spoke of downloading a PDF
The first Post in this thread was dedicated to that "PDF"
I must admit I'm not the sharpest Tack in the box,But It seems to me to be lacking some details?
IMHO
Chet
Thanks Grandma
vonwolf
Chet;
  Thanks for the quick response it looks like I'm kinda grasping at straws myself.
  Pete
