W.K.Coombs Open discussion thread
Started by ramset, April 25, 2011, 05:32:07 PM
gauschor
@bourne: thanks for the new input. You might have a point here.
And this is exactly it: where speculation and guesswork begins. Pointless. At least a real picture of the device would be helpful, to see that it's not only a big bad lie to waste our time and keep us busy with non-functional things.
@neptune: correct.
Bruce_TPU
Quote from: bourne on April 29, 2011, 08:42:15 AM
I don't want to be seen as completely negative towards this thread, but I think I might have something to add.
After reading the posts about the lever, I think Bruce's picture (reply #76) is wrong.
I think what is required is the lever be mounted 'through' the axle of the swing point as you have it now, enabling the pendulum to move up and down balancing the weight of the pendulum (1unit in front of upright 20 behind upright). This with the carriages side to side movement will allow the pivot or swing point of the pendulum to  move in a circle relative to its movement.
Just like your hand would do when swinging a ball on a string, make little circles to keep the ball constantly accelerating.
I hope this helps :)
Hi bourne,
Excellent post!  You may indeed be correct!  And that sounds exactly what he was describing.  Anyway can you put together a quick picture?
Cheers,
Bruce
bourne
Here is the picture I had in my head
There is but one true power in the Universe... that which we call Love. Todays present label and conspicuously absent from our named guardians tool kit.
gauschor
This looks indeed interesting... Thanks for the visualisation
ramset
WOW bourne,
Now I can better understand his "Timing" comment!
At the very least this will be fun to play with!
Thanks
Chet
Thanks Grandma
