solar x-ray influence on my AG-cell
Started by Walter Hofmann, April 09, 2005, 04:34:45 PM
0 Members and 64 Guests are viewing this topic.
betajim
Quote from: Walter Hofmann on April 10, 2005, 07:36:11 PM
Hi
I guess something is wrong on this picture, when the x-rays are all hold out by the earthatmosphere why does NASA give out warnings when the amount is to high?
here are the NASA satelite data from GOES 10 ,12 , http://www.sec.noaa.gov/rt_plots/xray_1m.html,
While solar x-rays don't incfluence the surface of the earth, they do have an effect on satellites and the ionosphere.
I guess the biggest concern is radio propagation being affected by changes in the ionoshpere. Oh, I guess
any astronauts would be interested in a increase of x-rays too!  ;)
Take care.
Walter Hofmann
Hi all,
after a 72 hour test run of one of my AG-plate cell in a closed lead box ( see picture) in comparisson with a not shielded AG-platecell I concluded that there is no difference in the reaction of the shielded cell.
The cell also increases the voltage under load condition meaning the initial voltage drops after connection a 50 ohm resistor as load down to 0.525 Volt ( 11 mA)within a few hours and then the voltage increases up to 0.720 Volt ( 14mA) and stay there for more then 48 hours now and counting. the Voltage is changing for around 0.050 to 0.084Volt in droping and rising.
the next step is to put the cell in the lead box in a galvanized sheet box, to see if something else influence the cells.
But right now is proofen that there is no connection between the solar x-ray and the reaction of the cells even if it coressponds exactly, another possibility whould be that somehow ether energy or how ever it is called influence the cells.
Overall I asume now that it is the internal cell system work what brings this strange results.
many comparisson test with all kinds of common batteries have not shown such results, with a resistive load they discharge with continuos drop of the voltage over some time frame and never increase the voltage under load conditions.
greetings
walt
Walter Hofmann
hi all,
strange I try to upload a picture from the leadbox with the AG-platecell yesterday but it is not there the message says I?O reading error. now I try to post it again and the message says now that there is allready a picture with the name.
I dont know what is going on.
I try it again now, I hope it works this time.
greetings
walt
Walter Hofmann
hi all
here is another pic with the lead box open
greetings
walt
Bruce A. Perreault
Walt,
Cosmic rays penetrate lead.  ;)
                   -Bruce P.
