Alternate Fuel for Diesel and Gasoline Engines - 100% off the Bowser
Started by ElectricGoose, May 09, 2011, 08:42:38 PM
evolvingape
Hi Everyone,
I was playing with the jigsaw earlier and look what I made :)
The Plasma Injection Gasifier Generator... Fondly referred to by myself as the PIGG...
A new design of low pressure 150lb BSP class gasifier, steam now injected to break down the fuel, wood + sand, to make us some Syngas :)
A cross fitting with two spark plugs acting as HV Arc Electrodes to create a Plasma Arc Reactor.
A GECV to control the Plasma priming and firing pulses...
A Scramjet nozzle to give us supersonic thrust...
A Turbine to convert that thrust into Rotary Moment...
A PMA to convert that Rotary Moment into AC or DC...
The possibilities are stimulating...  ;D
Points to note:
A Scramjet can operate in one of two modes, either the Scramjet is moved through the fluid to create supersonic compression... or... the fluid is moved through the Scramjet to create supersonic compression.
Only the taxpayer can afford Option one (although he never gets to play with it), Option two is far easier you just gotta blow some gas up!
The Scramjet Gas Bypass is critical... get the balance right ;)
The Plasma Arc Reactor, GECV, Scramjet, and Turbine, along with the Scramjet Gas Bypass must all be 316 stainless 3000lb class Hydraulic Fittings... ONLY!
A PAR, GECV and Scramjet Assy would make a mighty fine Scramjet Rocket Turbine... ;)
Be mindful of anything that starts to melt... ;)
Late at night when the World is quiet... you can hear it in the stillness of the moment... the sound you imagine a tumbleweed to make... it is the sound of the 100th Monkey whispering on the wind...
“Who has a PIGG?”
RM :)
evolvingape
Everyman Gasifier Unit Mk3...
An improved design increasing fuel capacity and decreasing height.
1” Nippling Tube provides off the shelf fire tube, however it is more expensive than threading your own.
RM :)
evolvingape
Here is the Everyman Gasifier Unit Mk4 :)
This is an improved version that requires no modifications of components to function, it simply screws together. I have also reduced the height even more and extended sump and hopper capacities in the search for the ultimate compact unit.
Equal Tees and Crosses are now used exclusively for the main body.
Hex Nipples make the joins with taper thread to seal, enhanced by sealant to lock the assembly and prevent the possibility of spiral leaks.
If a height reduction is desired then parallel BSPP Running Nipples can be used instead of Hex Nipples and the join is effectively internal adding nothing to the height, however sealant is essential as it is BSPP thread male to BSPP thread female.
The Fuel Hopper is now a cross allowing you to drill an end plug for the air intake, and then you can quickly remove the drilled end plug and fit a standard end plug to make the unit air tight and shut down the combustion process.
You can extend the fuel capacity by adding on more crosses if you desire and have the vertical room.
The Fire Tube is now 2" NPS which is a large internal bore to allow the gravity feed of much larger wood chips.
The combustion priming port has been moved up to reduce the height of the unit. Priming Fluid is now injected from a syringe or squirted in from a can. The fluid should be aimed at the fire tube, which will act as a guide, and the fluid will run down the outside of the tube and drip into the shaker basket in the combustion zone.
The most important change is that I have used Hex Reducing Bushes instead of Reducing Sockets. This is because the bush does not have an internal lip that needs to be removed. A parallel male BSPP thread such as on Nippling Tube will screw completely through without a problem, allowing you to join two inverted bushes without modification.
The hex reducing bushes also reduce the overall height of the unit in comparison to reducing sockets :)
I hope your all having fun playing with your big boy's LEGO kit!  ;D
RM :)
evolvingape
Hi Everyone,
I have just uploaded a video to youtube showing an advanced prototype concept for an Everyman Gasifier Unit...
Grab it quick before youtube ban it!
http://www.youtube.com/watch?v=THHx_FD3vfU
RM :)
