Alternate Fuel for Diesel and Gasoline Engines - 100% off the Bowser
Started by ElectricGoose, May 09, 2011, 08:42:38 PM
evolvingape
Repost from original thread:
Hello Everyone,
This thread is becoming very productive... it's so much better when all the kiddies play nicely together! ;D
It has been years since I even thought about gasifiers, and then I did not pay them much attention as I was far too busy with my turbines which are not based on hydrocarbon fuel.
My interest has been rekindled and I am going to give this subject some serious thought :)
If "TheOne" fancies adding HHO to the mix then it will be simple, I have already shown you how to do this... See pictures below and combine them into one device ;)
As a tip...
Schedule 80 316 Seamless 1/8 pipe has an OD of 10.3mm.
1/2 BSP hydraulic equal hexagon nipple fittings have an internal bore of about 11.9mm.
This means that the pipe can be sleeved perfectly into the fitting using just two pieces of brass tubing sleeve of the correct size. 1off K&S 7/16 x 0.14 (11.1mm x 0.355mm) Stock #137 and 1off K&S 15/32 x 0.14 (11.92mm x 0.355mm) Stock #138.
The HELIS insert is then centred in the ID bore of the pipe and then add electricity...
RM :)
evolvingape
Hi Everyone,
Here is an updated Injector diagram factoring in HHO production.
It is going to be really interesting to see what kind of fuel energy we can generate with a device like this...
RM :)
evolvingape
Hi Everyone,
Here is an inline filter at 10 Microns that might work very well as an atomiser with the Injector Mk2...
Just make sure it is electrically isolated from the circuit or the stainless steel filter will disappear!
http://www.magnafuel.com/products/accessories/filters/
RM :)
evolvingape
Hi Everyone,
Here is a good Loctite for sleeving... 638 Maximum Strength :)
It is highly viscous (gloopy) and works on clearances up to 0.25mm. It should electrically isolate the sleeves from the circuit if you do it right. Check it with a multimeter :)
You will also need ½ BSP Fixed Female Tees and ½ BSP Male x Male Adaptor (the tubes are sleeved in the adaptor and the adaptor screws into the tees)
This is a very exciting development we have created between us... anyone else notice the abnormally high number of people on the site today ? :)
RM :)
http://www.bearingboys.co.uk/Loctite_638_Maximum_Strength_Retaining_Compound_50ml-847-p#
http://www.customfittings.co.uk/brochures/CF100D2003/Default.html
http://www.nero.co.uk/3000lb_pipe_fittings
http://www.burnettandhillman.co.uk/en/
http://www.zx55.com/shopexd.asp?id=4512
http://www.cotswoldengineeringsupplies.co.uk/Hydraulic%20Adaptors/adaptorsproducts.php?item=BTFF&inthere=&line=Hydraulic%20Adaptors
ramset
Blest Technology
One of Many links on the web
http://thecoolgadgets.com/blest-company-plastic-to-oil-machine-home-plastic-recycling-made-easy/
I can see a nice little Cottage industry popping up from this,{sorta like the old "Moonshine" Biz ;D]
Chet
Thanks Grandma
