Alternate Fuel for Diesel and Gasoline Engines - 100% off the Bowser
Started by ElectricGoose, May 09, 2011, 08:42:38 PM
ElectricGoose
Quote from: ramset on May 13, 2011, 11:48:55 AM
RM
Which Plastic will you be Brewing?
Thanks
Chet
PS
Mr.Goose
Catalyst ??
http://www.overunity.com/index.php?topic=10722.0
I see many things in his Paper that look OH so familiar?
PPS
Who's "Bowser" And Why don't we like him??
Chet, good stuff mate.  I was hoping one of you guys would spot the article and make the link.  CATALYTIC people....NOT electrolytic cracking of water!!!  Electrolytic will always have you WAY behind and you will never catch up in the energy stakes.  CATALYTIC cracking you can take other elements and via the 'atomic' process use the energy that each element contain to dance a merry entanglement with each other.
Let me ask you this...you are faced with a big iron door and behind it is a treasure.  IF this door is 5 inches thick of solid steel and you only have a sledge hammer and a strong arm, given time (a lot of time) through hammering (resonance) you can smash your way through.  If that is your only task, it might take you weeks, it might take you years but you will get there.  HOWEVER, you have burned an immense amount of energy to do so right?!  This is what electrolysis is like.  Wasteful and hopeless.  NOW, imagine the door has a lock....YES this is a very strong one, the LAWS that bind the atoms together and govern the energetics of the universe for each element are strong.  However, for each of these locks is a key that makes the task so much simpler.  Given the correct key (or fiddling the lock under certain circumstances), these elements glide together 'interfacing' and then open up to form a new product (like syngas).  The end result is less work....more energy.  This is a simple way of looking at the catalytic process.  There are still other methods outside of this.
Will I be gasifiying plastic??  I doubt it.  All that matters is what YOU decide to do Chet.  I have my path which I am already on and you have yours to take.
Bowser?  You Americans don't know this term I didnt realise?  Another word for fuel pump.
bow·ser
(bou-zer)
- noun Australian and New Zealand
a gasoline pump at a filling station.
Origin:
1930â€"35;  said to be after S.F. Bowser  and Co., a Sydney manufacturer of gasoline and oil storage systems
Just like the Americans calling a Refridgerator a 'Westinghouse' or a Vacuum Cleaner a 'Hoover' I guess.
@RM - You seem to be getting fired up mate LOL.  Yes Hemp is a great product with loads of uses.
Best
evolvingape
Haha yes I was fired up last night, been having a drink with friends discussing the deliberate genocide of the worlds children. If there is a subject to fire me up, that's it. I know I should not post after a few but hey... times a ticking.
The point was about the furnace.
The Time Team episode showed the iron age technology of a fire in a pit, and the medieval technology of a furnace for firing pots. They also showed the simple process of making one.
The clay furnace can be made to any design very simply. All pipes and chambers are just voids in the clay and you can control the temperature.
If we can come up with a simple design to make a furnace that instead of making bricks makes gas, then no exotic material will be required to make a reactor, and everyone can have one, even the poor.
Effectively it would mean anyone could build a miniature power station in the back garden to provide fuel for the house.
Hemp is a great product and it grows very fast, they do not call it a weed for nothing. The food and health benefits are the bonus. If your going to grow anything for fuel then you might as well grow that.
RM :)
ramset
Mr. Goose
Chester's still in school!,And I don't like Banging my head against that door!
Just Like RM I like HHO,and just as RM is refining a new "Harvest" Technique
with his Turbine,I feel that HH0 will ultimately be a good fuel for our planet!
  In studying the Plastic to fuel I see Dioxin being talked about ,This is troubling, unless The Plastic can definately be identified always as "safe to proccess".
I could "Never" start down a road that Poisons the planet!
Still Studying..................
Thanks Fellows
Chet
Thanks Grandma
evolvingape
Hey Chet,
I was musing on what you said about HHO in your last reply and I had an interesting thought.
Think about how a bullet works. A primary explosive is inside the primer cap which is struck by the firing pin and this explosive then explodes, setting off the main less sensitive charge inside the casing.
If we were to use HHO as the primary explosive as has already been suggested and we were to pre mix this with atomised water just before injection to the chamber then one of two things will happen.
Either the HHO detonation will cause the atomised water to then detonate also, or, the atomised water will not detonate but will instantly vaporise and turn to steam.
Both of these possibilities will create a pressure wave that then has to force it's way through the water already in the turbine supplied by the K valve.
So we could end up with a 100% water powered turbine that only has very small energy needs to run.
Small amounts of HHO provide the primer to detonate and the gas expansion from either atomised water detonation or atomised water vaporisation provides the main impulse working fluid.
How's that sound to you ?
RM :)
ramset
RM
Knowing what I do about turbines,Your ideas give me "Goose Bumps"!
It all just Flows.............
It also frustrates me because of what I know about turbines![very hard to play at home]!
Chet
Thanks Grandma
