Muller Dynamo for experimentalists
Started by plengo, May 12, 2011, 01:04:21 AM
EMdevices
Here's an FFT of RomeroUK's pulse.
The first line is the DC value, and it's not zero.   I'll be using all the harmonics I labled to recreate a time domain replica that is smooth and curvefit by sines and cosines.  I'll discard the other ones as they are too small.
EM
PS,    I added the second graph, the result I was aiming for.  Notice how the flux is narrower going down and wider going up, with the added slant.   I expected this asymetry due to the biasing magnets, and the rotor having all the magnets with the same polarity facing one side, say N, and so there would be virtual S poles inbetween the magnets,  but these are not localized and can shift, i.e.  snap ahead and lag behind.
I added the third graphic, to show you how the flux is aligned with the magnets and rotor.  Notice the virtual S-pole is flexible and can advance and retard in location relative to the rotor, and that's what is happening, which is why we see the wider and the narrower flux waves (positive portion of flux is wider, negative narrower)  This S-pole snaps ahead and lags behind, because the biasing magnets have a N-pole facing down, and attract this virtual S-pole, which can shift because it's not emanating from a magnet, which brings up a very important point:
Make sure the biasing magnets are in OPPOSITION to the rotor magnets, which Romero confirmed.
Now here is a most important speculation:
As the S-poles snap forward to the nearby ferrite, and then lag behind as they try to pull away, AND THIS HAPPENS IN SEQUENCE, from coil to coil,  than there is a VIRTUAL "elastic magnetic wave" that is traveling and rotating 8 times faster than the rotor, and it is this virtual "magnetic wave of elasticity" that could be generating the FREE ENERGY,   This is a type of pole shifting in a rotating frame of reference!
and in the end,   we might realize that we are back at the mysterious   TPU, with it's "rotating magnetic field" or "turbine" effect.   !
and also in the end, we might realize that Spheric was right,  two bifilar coils with phase shifted pulses, will give rise to an interference pattern that TRAVELS AHEAD OF THE PULSE's ACTUAL SPEED, just like it happens in this motor due to the 8/9 ratio, i.e. the magnet/coil alignments travel at 8 times the rotor speed. And if you wrap this bifilar coil in a toroid, you can generate similar conditions.
EM
plengo
nul-points
nice reverse-engineering, EM - good work!
sounds like there's some evidential support for Bourne's 8x 'Reverse Travelling Wave' suggestion, prompted by his paper simulation of the coil/mag meshing
is there any chance you could repeat the exercise for the 'regular' (ie. non-Romero) waveform to see what the advantage is, when using Romero's setup?
great progress - thanks for doing this for us!
np
http://docsfreelunch.blogspot.com
teslaalset
EM, that's pretty good stuff to digest.
Good start for further investigations.
B.t.w. I also plotted the flux curves in my present sim results as presented in the sim thread.
It may be handy if I plot the magnet positions in those graphs as well.
I'll try to do my sim share to see what causes that difference in waveshape.
The waveshapes I posted in the sim thread are without bias by the way, so you might be right about the cause of the extra discontinuity in the wave shape. We'll find out.
chrisC
Quote from: EMdevices on June 08, 2011, 08:09:30 PM
EM
EM
Good stuff EM and thanks for taking the time to generate those graphs. Here's a couple of pics. of my setup and a quick scope shot.
Running off 1 driver and 1 pickup. Both biased with magnets. Input voltage ~ 10V, output across bridge 16.3V at 220mA. Probably spinning around 920 rpm and the corresponding waveform across the pickup coil. The front slope is not quite like Romero's but the back is about the same.
Stay tuned. Won't be able to update for a week. Out of town tomorrow. Keep up the good work guys.
cheers
chrisC
