Muller Dynamo for experimentalists
Started by plengo, May 12, 2011, 01:04:21 AM
redrichie
Not sure where to put this.  it is coil shorting but using the Romero circuit with a reed.  But combined in one unit.  Heres a video on the coil shorting effect I had written about about.  please excuse the sloppy setup.  ITs heartbreaking to spend so much time on a rig that is a dud.  so I had to redeem myself a little.  This is very crude and basic.  I was going to show a small light bulb lit from the output through a bridge into a cap.  But I burnt them out.  All of them.  I need a little bigger one.
The speed of rotor and the amount of Amp draw decrease is VERY dependent of input voltage and current..
No I didnt put a meter on it either.  Dont laugh, but I can generate enough energy to burn out light bulbs but if you forget to charge batteries for your meters then.....well youd be me!!! :o  ANd yes that was magnet launching at the end.
http://www.youtube.com/watch?v=kJcRh_3I3VU
teslaalset
Quote from: redrichie on June 15, 2011, 01:28:01 PM
Excellent video.
From my point of view, this is another indication that delayed BEMF caused by coil shortening is contributing to higher efficiency.
FreeEnergyInfo
e2matrix
Quote from: FreeEnergyInfo on June 15, 2011, 01:42:28 PM
http://www.youtube.com/watch?v=8G3kfcIl09o
Not sure if this has anything to do with the Muller dynamo but I don't have a clue what was being said as it sounds Russian.  It does look interesting but what was it about?
futuristic
It's Serbian. The man invented special type of single wire that can carry AC current to the light bulb.
The wire is not insulated and you can touch it with no danger.
It's very interesting but has nothing with this topic...
