Muller Dynamo for experimentalists
Started by plengo, May 12, 2011, 01:04:21 AM
plengo
Quote from: hartiberlin on June 15, 2011, 10:45:54 AM
Hi Fausto and all:
I wonder, what will happen, if you use no DC path in your output,
but only use 2 Avramenko plugs to generate the output DC.
So put on every coil output wire just an Avramenko plug with 2 diodes and 1 cap,
so for each coil you get 2 Avramenko plugs.
Then you have no DC current path.
Would be optimal also with coil shorting cause there you have fast changing waveforms...
and it would also not slow down the rotor.
Regards, Stefan.
Great idea. I will try that tonight.
Fausto
plengo
Quote from: plengo on June 16, 2011, 07:52:37 PM
Fausto
I finally had a chance to play with the AV idea and it was a disaster. I have to test again with more patience on the weekend.
Fausto.
hartiberlin
Quote from: plengo on June 20, 2011, 10:58:15 PM
Fausto.
Fausto,
don´t use electrolytic capacitors for it,
only use foil capacitors not too big, like 220 nanoF  or 1 uF foil capacitors and only use
1N4148 diodes for a first test.
Regards, Stefan.
