Tudi
Quote.. if you look at Gadgetmall's circuits...one of his JT designs will run over a year 24/7 on a single AA so that is a long time to test. ..
I know most people are here for science and progress. Some of us are here to change the world. That means if i can make my home lightning with 1 AA battery. Then to hell with measurement precision and errors. It simply works for a specific purpuse. Who cares if instead 10kHz your led will light up with 30Hz ? The point is that is working in a way that seems to be the same for you, but it consumes much less energy. It does not need to loop back forever, even if improved efficiency by a considerable amount it is a great achievement. No need to kill progress just because it is not exactly what you wanted to have.
Meantime, carry on with research :) Just don't get lost in the details like companies that get lost in the paper work before releasing a technology to "market".
Pirate88179
Tudi:
I agree.  I use JT lighting circuits to light most of my home most of the time.  I use dead batteries that others give to me instead of tossing out so, they cost me nothing for the light.  (Free light)  Efficiency is the main thing and if we get so efficient that it goes OU, so much the better.
Anyway, I have always been fascinated by the JT circuit as most on here know by now.
jmmac
Hi Chris,
I too am trying to replicate the circuit but with less success than you.
Regarding your measurements, i'm not sure i understood your method but, you can only calculate the output power multiplying current * voltage if these quantities are 100% constant over time (DC). Otherwise you'll get wrong results.
Regards,
Jaime
Quote from: hyiq on June 01, 2011, 01:39:50 AM
Hi Dr Jones.
I have replicated your Circuit. I have attached Pictures and the Calculator for others to use if they wish. I am getting COP = 2.5 at the moment. I think It may be a measurement error, but have checked three times and get the same result. Its early days for me and I will stay reserved at this point on my findings as there could be an error on my part. My goal is to make this self run like I mentioned but have not been able to make this happen yet.
I still think there is a 50/50 chance, but am convinced that some serious work will be needed to get a Bi-Polar Switch like Ron Cole/John Bedini's to make this run itsself.
All the best, and I will post more soon.
  Chris
P.S. My components are slightly modified compared to the schematic. Sense resistor = 1.5 Ohm. Load Resistor was changed also.I will post more information soon.
bolt
Absolutely  correct. The road to OU starts with energy savings but they need to be applied to real life practical use to be of any benefit. Alike RV motors big heavy 3 phase motors can run on as little as 10 watts to spin a 5 HP motor.  So it means nothing to demonstrate 10mw IN and 80mW out UNLESS you put that to good use.  LED lighting is of course a useful application.  There are many things that are OU and its no surprise the JT is OU and i have been saying this for years more often than not when looking at scope shots. I personally not too impressed lighting an LED for a year on one AA battery. My smoke detector runs for 3 years on a pp3 battery and beeps and flashes an LED for another 6 months LOL. This is 25 year old technology.  So use the JT principle and scale it up bigger.
Is it real? well yes of course see Ismael electric Car MEG DOT and DOE engineers tested to a COP of 2.7 running a 1000 watt load! But OU is not Looping too many people do not understand the difference. Call it energy savings first. For the same load your battery will last say 4 to 8 times longer. If EVERYONE used this technology that is around 1/2 Trillion dollars a years not going into the battery market. That is sure to upset a few people.
You can get the same use full size transformers and a lot more power. Looping is a different matter requires a COP > 2 plus system losses. In practice unlikely to loop under  COP 3 and tuning and critical RF application of load matching is essential to prevent OU being lost.
So don't spend too much time arguing about scope shots you never convince anyone that way and the arguing has been going on for many many years of how to measure IN and OUT see Ainsley Heater for that 1000 page thread saga. What changes things is when everyone just starts to use this technology then its just accepted as the norm like using microwave ovens was one of the biggest changes for  technophobics  in the home of the last century.
Focus your energies into getting a bit more power out and applying it to real life  applications then you will see the market sit up and take notice.
Hoppy
Quote from: hyiq on June 01, 2011, 02:28:32 AM
Hi Dr Jones,
I think at this stage my replication has too much room for error, so for this reason, may be best if I work a bit more on this first. Certianly after i get more results, that would be no problem.
All the best
  Chris
Chris,
Using your test setup with my Rigol DS1052E scope taking average voltage readings across 1R resistors, I get 3.5mA I/P and just under 1.0mA O/P. In power terms this gives an efficiency of around 30%. My Rb is 56K and running frequency is 2.63MHz. Load is 1K. Battery supply voltage 3.0V.
Hoppy
