You gotta wonder why they are bothering with all that, since Defkalion just demonstrated the Holy Grail and made all that UofM work obsolete. They are probably dismantling the SKINR lab right now and retooling for Hyperions and Rossi HotCats in an effort not to fall too far behind. Imagine... a university lab running a fullscale LENR/CF research program gets trumped, the veritable rug pulled out from under them, by a commercial enterprise Defkalion and a garage tinkerer with a prison record Rossi.
I guess the "show-me" state got shown, good and proper, by Defkalion. Didn't they?
woopy
Hi Steven
thank's a lot for infos
I have seen that Mr Biberian have also made a resumee of each day main lectures  on his blog ( in french= lot easier for me ), very interesting, to get in touch ( at distance) of  this conference. Thanks very much to him.
Concerning the Defkalion demo he ( Biberian ) just noticed that the output water used to measure the efficiency, was in state of  vapor and he would prefer that the  measuring water should stay to liquid water state , in order to avoid measuring error between dry and humid vapor . He stated also that Defkalion is working on that problem.
Thank's to all for going on the good work
laurent
JouleSeeker
  Thanks to you, Laurent!  I personally find your experimental progress inspiring and I wish to encourage you.
  Can you tell us where Dr Biberian has his blog?  would like to read.  (I can read French fairly well; but I think you would laugh to hear me parlez Francais.)
  From the conference today:  http://www.youtube.com/watch?v=AKgUinHLvuo
"Tough questions on Defkalion demo by Dr Kidwell at ICCF-18".
Occurs to me that Dr Kidwell asked the tough questions as you might do, TK!  I assure you, there is scientific scrutiny going on -- as one might see from the vid.
tagor
Quote from: JouleSeeker on July 25, 2013, 11:14:08 PM
Hi !
here it is :
http://blogde-jeanpaulbiberian.blogspot.fr/
JouleSeeker
Merci, Tagor.  Prof. Biberian dit:
La Conférence ICCF18: mardi 23 juillet, deuxième jour.    La conférence a commencé par une table ronde sur l'entrepreneuriat et l'innovation. Elle était animée par Matt Trevithick qui dans son introduction  a indiqué que des financements pouvaient maintenant entrer dans le domaine de la fusion froide. Marc Johnson de ARPA-E a expliqué comment faire pour mettre en place un dossier auprès des investisseurs potentiels. Il a cité une phrase d'Ernest Rutherford qui m'a beaucoup plu: "Nous n'avons plus d'argent, il est temps de commencer à réfléchir". Doug Moorehead de Earl Energy a fait part de son expérience dans l'accompagnement des entreprises.
Nous avons pu voir en direct par internet la démonstration du réacteur de Defkalion depuis Milan. C'est Alex Xanthoulis qui a présenté le réacteur.  La démonstration a duré toute la journée, et nous avons eu trois connexions, l'une le matin, l'autre l'après midi et la troisième le soir. Le réacteur comporte une partie centrale contenant 60 grammes de matériau actif dont 5 grammes de nickel. La différence est le support. Le poids total de la cellule est de 8,54 kg. Un circuit d'eau refroidit la cellule. Le débit d'eau était d'environ 0,2 litre/minute. L'eau provient directement du robinet après passage dans des filtres. L'eau ressort sous forme de vapeur à haute température. Le système est calibré avec de l'argon à la place de l'hydrogène. Le réacteur fonctionne avec à la fois trois résistances placées à l'intérieur de la cellule et des bougies permettant de produire un plasma. A la fin de la journée, nous avons appris que le réacteur avait fourni 5,2 kW avec une puissance d'entrée de 2,0 kW. Je me suis posé la question de savoir pourquoi le débit d'eau était si faible, ce qui faisait que l'eau ressortait sous forme de vapeur. En augmentant le débit, l'eau ressortirait sous forme liquide et le calcul de la puissance thermique serait plus simple. Avec la vapeur d'eau on est obligé d'utiliser la chaleur de vaporisation de l'eau, ce qui est risqué, car la vapeur peut être humide. Si c'était le cas, les résultats seraient surestimés. J'espère que Defkalion pourra corriger cela.
Oui, tres important.
