0 Members and 114 Guests are viewing this topic.
hyiq
Quote from: nul-points on June 02, 2011, 10:16:49 AM
BTW  could you help those of us who have smaller displays on our computer systems?
it would be very helpful if you could reduce the size of your images before posting, because wide images force all the text on every post on the page to require horizontal as well as the usual vertical scrolling in order to read all of each post
a maximum width of around 800 pixels should still leave a suitable resolution for most images - and it should also allow folks with limited screen-width displays to be able to read the entire page just by scrolling down
http://docsfreelunch.blogspot.com
Hi nul-points,
Appologies, Yes I will make the images smaller. Sorry. I have seen to many small bad resolution images showing really nothing of any value so I try to always get the best clearest images I can to really make the image of value to others.
All the best.
  Chris
e2matrix
hi Chris
thanks for sharing your results with us, it's encouraging that they are supporting Steven's own results - the set of successful replications is growing!
thanks in advance for your help with this
i meant to say above, nice clean build you have there - compared with my 'birdsnest' construction!
all the best
np
Sorry to drag this off topic for a minute but I basically agree with what you say on pic size.  However as my main browser since the early 90's has been Opera if you haven't tried it you'll find it's great for dealing with this situation.   Hit the minus key on the keypad a couple times (each press reduces page size 10%) and everything fits nicely on the page.  Or just go direct to the menu made for directly resizing with your mouse and jump down to or up to whatever size you want (menu is 20% up to 900%).  The plus key sizes it up also.
Now back to our regularly scheduled OU discussion :)
hyiq,  am I reading your screen caps correctly that you are getting about 19 times OU?  While I realize we are dealing with very low power here if you do have 19 > COP then isn't there a way to loop it?  That would certainly end any argument about measurement errors.
  I would envision getting it started with a battery and using a fast multi-pole relay to switch out the battery and switch into looped mode maybe with a cap in there to hold it until its self running.
hyiq
Quote from: e2matrix on June 02, 2011, 06:12:55 PM
Hi e2matrix,
Yes.
My goals are:
1: Replicate this effect - done.
2: Understand this effect - In-progress.
3: Try to scale up this effect - TODO.
4: Self Power and power a Load - TODO.
I dont know if any of you know, but I have played with this type of circuit for many years:
http://www.hyiq.org/Library/Catching_Radiant_Energy.htm
Not exactly the same circuit but similar concept. I guess this is what has drawn me to replicate Dr Jones Circuit.
Nikola Tesla : "He threw the switch for a brief instant, and was again caught off guard by the stinging pressure wave!"
Could we be seeing the same effect?
All the best.
  Chris
hyiq
Hi All,
I have a Bi-Polar Circuit working but this is really giving me VERY unusual Measurements on the scope. I am getting Negative Current on the sense resistor on the input. Please let me know what your thoughts are. If I flip the Earth and the probe around on the input I do get a positive current reading.
All the best
  Chris
gyulasun
Hi Chris,
Sorry to chime in, I believe xee2 made some good comments on the measurements in his Reply #143  http://www.overunity.com/index.php?topic=10773.msg289292#msg289292
Have you considered those comments or may be you disagree with them?
Thanks,  Gyula
Quote from: hyiq on June 03, 2011, 07:08:55 AM
Hi All,
All the best
  Chris
