0 Members and 31 Guests are viewing this topic.
gyulasun
Quote from: hyiq on June 03, 2011, 06:35:42 PM
So just to confirm, move the diode in Circuit V5 in Reply #174 to the other side of C3? So the Cap is not affected by the diode?
Yes,  that is what I thought as a good step but my brain did not work fully last night and did not consider that a forward biased diode (from battery 4V) just conducts continuously and is a few Ohm resistance...  so any small AC coming from the circuit towards the battery will pass unrectified...
sorry for this.
So a series diode even in the negative rail would not catch the AC either...
a different approach like nul-points series coils put in the rails may be a step in the good direction, the series coils increase inner impedance of the battery from AC point of view.  But it seems still difficult to catch the very small AC current or voltage amplitudes...
Gyula
hyiq
Quote from: gyulasun on June 04, 2011, 06:50:59 AM
sorry for this.
Gyula
Hi Gyula, and All,
Yes you are right. Early tests show a huge increase in output by simply winding and wiring the coil like a Tesla Series Connected BiFilar Coil.
Voltage goes way up.
4 Volts / 9 Turns = 0.4 reoccurring. This is the voltage between each winding on a single filar coil.
In our case, whats the Math for this?
2 Squared / 0.4 Squared = 4 / 0.16 = 25 times more efficent..... Interestingly a Tri-Filar Coil only makes it 9 times more efficent.
All the best
  Chris
hyiq
Hi All,
This is the best Circuit to date. I will get some measurements through soon. But this is considerably better than my last results. Nikola Tesla's Bi-Filar coil makes a huge difference to the output. See last post.
All the Best
  Chris
xee2
Quote from: hyiq on June 04, 2011, 09:20:48 PM
Good research. Do you think the way you wound the coil is better than just doubling the number of turns on L2?
nul-points
Quote from: hyiq on June 04, 2011, 08:26:16 PM
  Chris
interesting to have confirmation of this, Chris - i wind my coils like this,also
unidirectional wind per layer, with next layer interleaved in same direction -  a part turn to get back to start each time
then repeat for each/any next two 'layers' - etc
thanks
np
http://docsfreelunch.blogspot.com
