Thanks to ALL for your help!!
Mk1
@Joule seeker
I see one more improvement that could be done , Variable cap to tune the Freq .
JouleSeeker
Quote from: Mk1 on May 29, 2011, 12:39:29 AM
@Joule seeker
Appreciated and noted.  Lots of opportunities for those "playing" with this circuit.
I'm most interested at the moment in double and triple-checking the Pout/Pin results.
JouleSeeker
Quote from: xee2 on May 28, 2011, 12:24:32 PM
@ JouleSeeker
I am sorry if I misunderstood how you are measuring the output power. But how can you measure the whole cycle using a scope? The voltage on the scope is only valid at one instant of time and changes over the cycle. This is how I measure efficiency > http://www.youtube.com/watch?v=smOiVmKv9f8
I take a time window (2useconds typically) in which there are many cycles, to acquire a good value for the Mean power, both for input and output power.  Let me explain further:  the Tek 3032 math multiply function allows me to get INSTANTANEOUS power by multiplying for me Vin (t) * Iin (t) -- and this power waveform is plotted (red waveforms above).  Then the MEAN is extracted over numerous cycles.  Same for Output Power.
Again, I'm seeking non-oscilloscope methods to triple-check the Pout/Pin observations.
Thanks Kee2 -- I followed your posts on the JouleRinger especially, months ago, which inspired developments of this circuit.
JouleSeeker
Quote from: hartiberlin on May 28, 2011, 07:38:46 PM
Here is a replication video from User itsusable:
http://www.youtube.com/watch?v=vV4xMeZ_41Y
Seems it is not so easy to measure the output power in his case.
Regards, Stefan.
I appreciate Itsu's efforts (vid).  VERY true -- "it is not so easy to measure the output power in his case."  Again the importance of non-scope methods to check and verify.
@hyiq:
QuoteOnly one way to show this is OU, is to self-power then power a load if possible. Measuring this type of wave form is always going to be a problem even with the most sophisticated equipment.
If it self Powers itself its OU. Its easy to get ones hopes up and then be let down by a silly measurement error. I have done it before. All the Best Professor and keep up the good work.
  Self-powering is a great method and demonstration, certainly.  The problem here (so far) is that the output power has a substantial AC component to rectify, also the output voltage (@ approx 7 volts using DVM, across  9.7Kohm Rout ) is larger than I like for the input Voltage.
Yes, I would like to see a self-running device, but I do not think this is the ONLY method of verification.  See alt methods I'm pursuing (discussed briefly above).
Mk1
@Joule seeker
Maybe it is time to recycle the OU term , maybe recycling energy could be a better greener image , for over efficiency circuits.
