0 Members and 64 Guests are viewing this topic.
SkyWatcher123
Hi folks, I'm trying out a 6 filar secondary with this circuit and testing out different wiring setups.
Hi allcanadian, very, very well said, though I would rethink the term persons as that is the term the manipulators use to call the fictional human being from birth.
Hi Stiffler, So I would ask then, how is that working out, your quote, "I always thought the definition of the American Dream was the ability to work for something and gain in return, not to have it all handed to you, can not understand where incentive and motivation would ever come from if you were assured of a few taking care of the masses."
As we can see, when a culture of human beings does not share all their time, energy, labor and ideas freely and expects a reward or selfish gain, well I can see the rewards we reap and that is more and more dictatorial government and systems that mirror our thinking or conditioned thinking at this point.
So we get worthless ink paper, so that a few can steal our time, energy, labor and ideas and place the majority of the so called gain in their control.
Sure sounds like that dream is working, though it has backfired and is working for an elite few. Be cautious of what you wish for, as if it is not for the good of all, this is what happens.
Cause and effect.
This is not political or scientific, this is spiritual and spiritual knowledge carries the highest wisdom.
peace love light
tyson ;)
hartiberlin
P.S: Congratulation on the new born baby Dr. Jones and family !
P.P.S: When tuning the circuit we tested today at Per-Johan´s place, I saw,
that it works like a Joule Ringer circuit.
Changing the Base current pot just changes the frequency of the
Spikes and the waveforms looks very simular to the waveforms of a
JouleRinger.
The 3rd coil on the core is the easiest way to get rid of the different DC level problems
when you want to feedback the output to the input.
Without the 3rd coil we tried to use the FWBR directly parallel at the emitter coil
and there it charged up a 2200uF to about 5 Volts, but you can´t feed this back to the input
directly cause otherwise you short out one diode of the FullWaveBrdigeRéctifier .
So the easiest part to work around this is to put a third coil around the core
and use this to extract the energy from the circuit.
Then you can also easily feed it back to the input,
cause you have no DC level problems.
Regards, Stefan.
hartiberlin
Here is again the circuit diagram from the video
for those that can not watch the video.
Regards, Stefan.
nul-points
Steven
here's the initial data for my ongoing logging of a supply cell voltage on my latest SJ1 variant test (schematic posted on 22nd June, post #427)
as you can see, the cell terminal voltage (green trace) has been increasing for nearly 120 hours, so far, since this particular run started (around 2am on 22nd June)
the circuit is supplied by two AAA NiMH cells in a reasonable state of charge - i'm logging the terminal voltage of one cell, the other cell is also increasing in voltage at a similar rate
at the moment it looks to follow my earlier SJ1 variant cell voltage results i posted a couple of weeks back
the test will need to run for at least another few days to see if it's the same battery 'relaxation' effect seen with the earlier circuit
the previous results showed the battery voltage increase peaking after approximately 190 hours continuous operation, so that is the target for this circuit to beat!
(BTW  i eventually lowered the logger a few inches, to be at the same height as the DUT near the floor. and that brought the two temperature readings closer - although for about a further day the core temperature was still slightly less than the 'ambient')
as before, i'll keep you updated with developments
the possibility to have access to some full-calorimetry equipment is very encouraging!  i hope that proves acceptable with your contact
i'm sure you'll get plenty of ideas for controlling the run - i'll throw in the possibilities of either having a magnetic reed switch holding off connection between DUT & supply cap until you remove an external magnet (assuming suitable materials & distances) - or a tilt-switch which would just need two distinct orientations of the calorimeter - 'load' & 'run' (assuming test gear can be 'rotated')
it's possible to get stand-alone micro-loggers which might possibly fit alongside the DUT, within the calorimeter - data can be downloaded back to a PC via USB afterwards
hope this helps
thanks
np
http://docsfreelunch.blogspot.com
jmmac
Quote from: JouleSeeker on June 26, 2011, 10:19:57 AM
Jaime -- use of an optocoupler is a good idea.  Awaiting your result with the resistor(s) added... for comparison with a JT-type circuit.
Professor,
As you requested, i tested the optocoupler version with an added resistor between capacitor plus and led anode. I tested 3 setups: with R=0 Ohm; R=22 Ohm ; R= 68 Ohm. The led brightness is almost the same in the 3 setups, i almost can't see a difference. The circuit was tested without multimeter or scope connected and with the pulse generator electrically separated. The pulses had a frequency of around 50Hz and duration of around 540ns.
I made 3 measurements for each setup letting the cap discharge from 2.50v to 2.00v. I got the following average Pin:
R=0 Ohm   : Pin = 0.585 uW
R=22 Ohm : Pin = 0.578 uW
R=68 Ohm : Pin = 0.575 uW
