Thanks to ALL for your help!!
good battery tester
Started by hartiberlin, June 03, 2006, 05:16:24 PM
hartiberlin
Hi,
I just have found an interesting battery tester item on EBay,
which can test pretty nicely a range of lead acid batteries.
So if you need a battery tester for some pulse motor
charging tests of your batteries,
have a look at this, then you can verify if your battery really
has a nice charge or if the voltage of your battery is only
a surface charge that does not last:
http://cgi.ebay.de/ws/eBayISAPI.dll?ViewItem&item=6035624194
There are 2 different types available, one with 40 and the other with a 100 Amperes
test current, so you can see, if your battery is weak or not...
