Thanks to ALL for your help!!
Romero's experiments and OU principles
Started by plengo, June 10, 2011, 08:26:08 PM
neptune
@Bolt . Many thanks for info re the permanent magnet motor mod . This is doable but would invove lathe work to arrange that the spinning mass is on 2 bearings . Big question is , is the result OU . 10 times the ouput is good , but what effect would this have on the input .
bolt
Quote from: neptune on June 14, 2011, 04:57:24 PM
The up to 10 times rating is the power handling factor of the motor converted to so a 1kw motor can become a 10kw generator as the power is shared over ALL phases as all times. So this is NOT the COP. I don't know is the answer my guess most of these things IF they work have a COP between 2 and 10 so lets settle for 5:)   Half decent size motor driving at using 1kw should give like a 5Kw output. Yes it needs machine work for bearings etc but i'm told its VERY well worth the effort.  Looping stuff is very difficult even if it has very good COP. Requires DC to AC inverters  usually in the feedback path and some method to control the amount of energy going around the loop to run the driver. If you stick with all DC perhaps PWM can be used. Free Energy is not FREE typically you still looking at 2 bucks a watt building from scratch. "TOYS" probably cost more like 50 bucks a watt so it scales up cheaper:)
energia9
so can anyone help me where to find these ferrites? am i being ignored?
thank you
lumen
I like the 5.76khz.  72 * 2400rpm/60 sec =2880 cps   x2 because the FWB converts the negative transition to another positive transition.
No?
neptune
@energia9 . Please be patient , when the right person sees your question , someone will help you .
@EM devices and Lumen . Just had another think about this frequency thing . I think that what matters is the actual frequency of the AC in the coils rather than the frequency of the DC "ripple" after the bridge rectifier . So It is this AC frequency that will determine the need for litz . Or not . That is what I think . I would of course like to know what you think .
