Safe One Wire energy transfer by Serbian inventor Milutin Miletic
Started by hartiberlin, June 16, 2011, 11:51:28 AM
dradak1
Guys send me what you like to be translated from Serbian - I will do my best.
FatBird
dradak1,
Thank you for wanting to help with the translation.
Just download the PDF Patent (see below) and see what you can do with it.
If it is a lot of work, maybe you can post here 1 or 2 pages each day?
Thank you.
dradak1
Since translation of whole patent will take long time (my time is limited) - I suggest that we go with different approach. I will explain in short what is patent about than if you have specific questions point to the page and/or paragraph and I will translate.
Patent is for secure power cable - main idea can be compared to coaxial cable. cover is metal pipe used as conductor for joined ground and zero-phase (also used as protection for hot wires against moisture, physical contacts, damage, short circuit ...) and inside is insulated hot wire/s (can be 1 or 3).
I hope that's a good start.
The biggest technical 'glitch' is that there is no such thing as one-wire energy transfer.  Same thing for Peter Lindemann's 1988 clip where he thinks he is demonstrating one-wire energy transfer.  There is AC displacement current traveling through the air that is completing the circuit and acting as the invisible second wire.
dradak1
Quote from: MileHigh on June 28, 2013, 06:33:46 PM
As much as I read into the patent he is not claiming one wire transfer - he claim safer A/C transfer - reducing fatalities, power outages and so on due short circuit.
