Safe One Wire energy transfer by Serbian inventor Milutin Miletic
Started by hartiberlin, June 16, 2011, 11:51:28 AM
FatBird
BUT he was lighting up an INCANDESCENT Bulb and Running a DRILL MOTOR
with 1 wire, from a device that looks like a YARDSTICK.
NO CIRCUITRY that is apparent in his videos.
the_big_m_in_ok
Quote from: FatBird on December 31, 2013, 07:54:57 AM
fatbird hs a point.   The invented contraption does actually look like and ordinary yardstick in appearance.   Uh, how does he do it?   Has anyone here at all ever seen a schematic for this thing?
WHOA, wait.
That thing looks like a non-magnetic rod wrapped in wire with a full-wave bridge at the output and it appears to be plugged into a wall power mains outlet, possibly with hot and neutral or hot and ground connected at the input.
Unfortunately, I don't have an article for this to show you right off, but this is mentioned on the 'Web, for sure.   I've seen what I'm talking about.   This is mostly mutual induction, AFAIK.
--Lee
slotinnn
hey guys
here is the answer :)) we re chasing gosts
the man never states single wire trasnfer at 50hz .... in fact his invention is called safe wire  and relatates to safety transfer electricy... this is the fact
apart of that he clearly says it makes 2 changes... changes the shape of the zero  making it a tube and ground it also...
the transfer is made from the inner wire 3 throught the load  to the external wire 1 which needs no external protection because it is grounded.
the tricky thing that fool all of us is that the external wire 3 has no plastic protection and seems a single wire... instead it has the phase wire in the middle of it...as the invention clearly states :))
i don t see this an invention which may comapre this guy to tesla....
and now we all can see how a tricky youtube title can fool all of us ....
forest
Quote from: slotinnn on January 23, 2014, 02:58:13 AM
hey guys
here is the answer :) ) we re chasing gosts
the tricky thing that fool all of us is that the external wire 3 has no plastic protection and seems a single wire... instead it has the phase wire in the middle of it...as the invention clearly states :) )
Yes, I knew it was kind of coaxial cable used, but what was misleading is the statement of inventor that it can power loads more efficiently, which is not truth of course. HOWEVER, there is still possibility that the wire is only one part of invention or at least I would go further and try to convert AC into PURE one wire HF with coaxial wire passing it and the shield around as a return path grounded. THAT would be MUCH MUCH SAFER
the_big_m_in_ok
Quote from: the_big_m_in_ok on December 31, 2013, 02:55:57 PM
Here, I found this:
http://www.overunity.com/12340/joule-lamp/dlattach/attach/99004/image//
       Time's short on this library computer.   I don't have the time to analysis this at my leisure, but this is what I thouhgt appeared to coincide with the 'safe one wire' power transfer application/concept.
--Lee
