Safe One Wire energy transfer by Serbian inventor Milutin Miletic
Started by hartiberlin, June 16, 2011, 11:51:28 AM
SchubertReijiMaigo
@ Forest and ElectricGoose, OK I understand, square or pulsed DC have a lot of harmonics, I just know that a square wave have a number of harmonics that tend to infinity !!! (Fourier Transform). All this harmonics is energy also, maybe you have right, the OU can be from harmonics, In AC system harmonics are an undesirable effect because it can flow a lot of ampere (reactive energy)...
After all there is a reason Tesla switched from AC to pulsed DC later...
sm0ky2
has anyone tried to build one of these things?
you can turn it into single-wire transmission by simply putting a diode on one of the 2 A/C wires....
but where is the return path? sure you have 120v pulsed DC, but with respect to what? wheres the potential? the "ground" ?
is it simply earth-ground? using the fault-circuit?
how is the power drawn off of the 1-wire?
forest
Quote from: sm0ky2 on June 20, 2011, 12:14:42 PM
Read this http://www.tfcbooks.com/tesla/1919-05-00.htm
Fig 4 will explain all and even more !
3 in one wire : phase, return and ground
SchubertReijiMaigo
Or another theory what about two current in same wire, with the skin effect ?
I have make some experiment, with a so called radiant oscillator...
and I have noticed with the skin effect you can carry two current in same wire, for example a DC/low frequency current for a path and a high frequency for the return path, everything in same wire ?
forest
Quote from: SchubertReijiMaigo on June 20, 2011, 03:12:32 PM
How that could help ? Still low frequency current would kill. However if it's high frequency very low or no current modulated by 50Hz envelope ....
